roybatty666 Posted August 23, 2008 Share Posted August 23, 2008 Hi all after fetching some fantastic condition from JST yesterday (thanks again James) I am a bit stumped as to the white to paint them as there is no paint code stamped on my 1990 Defender, I think it may be Davas white as it is pretty off white compared to my chums 97 Disco which he says is Alpine white. As there were only 2 whites used in 1990 (according to the colour chart posted on here) Any ideas on the correct colour would be gratefully received. I am planning on rattle canning it (properly rubbing down between layers etc) as green laning makes a mess of the paintwork anyway so it doesn't need to be perfect. What is the opinion of Halfrauds paint quality and colour match? Alternatively where is a good place to get some. finally how many cans to do 2 doors inside and out? Thanks as ever Quote Link to comment Share on other sites More sharing options...
Marco Posted August 24, 2008 Share Posted August 24, 2008 It could be Ivory White, Chamonix White, Davos White (same number LRC354) but difficult to say. If it's a turbo diesel or n.a. diesel I guess it will be the same as my 1989 white 127 which is LRC354. Spraying with cans, ready made color cans are not 100% matching IMO / experience. Guess you will need at least 2-3 cans per door inside out. You can have cans or paint mixed up at an automotive paint supplier. Consider painting the door with a roller in stead of cans. Cheers Marco Quote Link to comment Share on other sites More sharing options...
Tim_NZ Posted August 24, 2008 Share Posted August 24, 2008 Have a look at: http://www.stephen.hull.btinternet.co.uk/nonmetallic.html Hope it helps, Tim Quote Link to comment Share on other sites More sharing options...
roybatty666 Posted August 24, 2008 Author Share Posted August 24, 2008 It was a TD but converted to 200tdi I think it could quite well be LRC354 Is rollering a better option then? I would have thought the finish would be far from smooth? Quote Link to comment Share on other sites More sharing options...
Marco Posted August 24, 2008 Share Posted August 24, 2008 It was a TD but converted to 200tdiI think it could quite well be LRC354 Is rollering a better option then? I would have thought the finish would be far from smooth? I do give it a good chance yours is LRC354... With a roller you can get a very good finish. On my Landy there is no real difference between the DIY spray paint job (compressor) and the doors which have been roller painted. Main advantage of a spray can (or spray gun) is the fact that a profiled item like a door (inside) will be much easier to paint. Quote Link to comment Share on other sites More sharing options...
