kingdong Posted August 24, 2008 Share Posted August 24, 2008 Hi all just a thought as i haven't taken any measurments but is it possible to fit a smaller cooling fan of another vehicle to the water pump of a 200 tdi fitted into a s11a i no you are soposed to fit an electric fan but i thought i would ask. graham. Quote Link to comment Share on other sites More sharing options...
scumduggler Posted August 24, 2008 Share Posted August 24, 2008 Hi alljust a thought as i haven't taken any measurments but is it possible to fit a smaller cooling fan of another vehicle to the water pump of a 200 tdi fitted into a s11a i no you are soposed to fit an electric fan but i thought i would ask. graham. Hi there will be vey little room between the w/pump pulley and the rad if you've used the series engine mounts & tdi radiator. Also half of the fan will be below the radiator and ineffective. If you've used the series rad there's more room but it'll still be low down. I've put an electric fan in front of the rad and never had to used it. Russ Quote Link to comment Share on other sites More sharing options...
kingdong Posted August 24, 2008 Author Share Posted August 24, 2008 Hi scumduggler which electric fan did you use graham. Quote Link to comment Share on other sites More sharing options...
rjblank Posted August 24, 2008 Share Posted August 24, 2008 Hi there will be vey little room between the w/pump pulley and the rad if you've used the series engine mounts & tdi radiator. Also half of the fan will be below the radiator and ineffective. If you've used the series rad there's more room but it'll still be low down. I've put an electric fan in front of the rad and never had to used it. Russ I have a BMW 740 pusher electric fan on mine, but it runs so cool that I don't ever have to turn it on... It fills up the whole radiator and fits perfectly in the radiator panel. I have pics in my 200tdi thread. Quote Link to comment Share on other sites More sharing options...
kingdong Posted August 24, 2008 Author Share Posted August 24, 2008 Hi rj yeh i have seen it looks great i will have a look on ebay tomorrow. graham. Quote Link to comment Share on other sites More sharing options...
rjblank Posted August 24, 2008 Share Posted August 24, 2008 here are some detailed photos of the fan install. Quote Link to comment Share on other sites More sharing options...
RobotMan Posted August 25, 2008 Share Posted August 25, 2008 I have a Kenlowe mounted in front of the rad, a really old one I've had for about 16 years now. Quote Link to comment Share on other sites More sharing options...
tuko Posted August 26, 2008 Share Posted August 26, 2008 Graham, like everybody else I'm using a pusher fan but from a Citroen BX 19. Wired in to run automatically or manually by a switch. Todd. Quote Link to comment Share on other sites More sharing options...
