stevie1690 Posted August 24, 2008 Share Posted August 24, 2008 Hi there im looking for as much advice and inform ation on fitting a 300tdi manual into my 3.5 v8 auto classic range rover thanks stevie Quote Link to comment Share on other sites More sharing options...
bishbosh Posted August 25, 2008 Share Posted August 25, 2008 Buy a complete Discovery with the drivetrain you want and swap it over. Break the Disco when you're done and recoup some of the initial outlay. Quote Link to comment Share on other sites More sharing options...
stevie1690 Posted August 25, 2008 Author Share Posted August 25, 2008 Buy a complete Discovery with the drivetrain you want and swap it over.Break the Disco when you're done and recoup some of the initial outlay. Cheers mate already bought full disco have the rolling chassis sitting in garage with drive train still attached cheers stevie1690 Quote Link to comment Share on other sites More sharing options...
jerboa Posted August 31, 2008 Share Posted August 31, 2008 Cheers mate already bought full disco have the rolling chassis sitting in garage with drive train still attached cheers stevie1690 Im thinking of doing pretty much the same with my '86 efi RR, does it matter much in terms of ease of fitment whether you go for 200 or 300 tdi? And will it go straight in with out having to do new mounts etc? Quote Link to comment Share on other sites More sharing options...
bishbosh Posted August 31, 2008 Share Posted August 31, 2008 200 or 300 makes little difference I think as long as you don't have a 300 with ECU etc. In both cases (certainly 200) the engine mounts will need to be changed. Simple job though. Quote Link to comment Share on other sites More sharing options...
Guest noggy Posted August 31, 2008 Share Posted August 31, 2008 to be honest, you meres will buy a disco and do a body swap, its about as easy. Quote Link to comment Share on other sites More sharing options...
sheltie50 Posted September 11, 2008 Share Posted September 11, 2008 The only body mod to remember is--- the bulk head where the rear of the tappet chest will sit needs to be altered if you want to remove the rocker cover in the future, better to cut out a bit and maybe reweld to give a suitable recess. Use Disco engine mounts I dont think the auto box will be a very good match for the 300tdi. Quote Link to comment Share on other sites More sharing options...
