HELP! - Rangie Buying Advice
nathanmonkey
Hi all,
I am looking at an RRC that is an MOT failure, it needs - Inner Sills, Footwells, and Outriggers welded/replaced. Can anyone tell me about how difficult this is likely to be, or what it would cost at a resonable garage.... bearing in mind that I am a total novice - and the clumsyist man around!
Thanks for your help!
Nathan
If that type of work is not your bag then go find a tidy RRC.
The work you describe, repaired at a garage, will cost more than the value of the vehicle.
It only becomes viable if you have a welder and a pile of sheet metal and are happy to dive in and fix it yourself.
Steve
Personally I would look elsewhere even if competent -there are thousands of RRCs out there at the moment, none going for any money at all.... the one you describe is probably worth more as scrap than a potential vehicle for someone.
