V8 alternator mounting brackets?
Steve 90
Need to get a second alt on the 4.2 ive just bought for the challenge truck. Im sure ive seen alternators mounted on both sides of the V8 on O/E brackets. I will Fab a bracket if I need to but if theres something available off the shelf then it would be much easier and quicker to go that way. Can anyone confirm if they are available and if possible a part number would be brilliant. Any photo's so i can have an idea of what they are like would also be great.
Thanks in advance.
Steve.
Yep they can be mounted either side. O/S without aircon, N/S with aircon as compressor takes the place on the O/S.
Which side bracket are you needing? I may have one in the shed.
Cheers for the reply. I definitely need the RH (or left as you look at the engine from the front), Probably need both!
