Exmoor Beast Posted August 29, 2008 Share Posted August 29, 2008 Straight out through a hole in the rear crossmember takes some beating, whose was the V8 marine blue Series truck cab that came down here a few years back when we did a playday over near Taunton and a days laning? Beautiful thing it was... Will Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted August 29, 2008 Share Posted August 29, 2008 So for the scrutineering, can the exhust exit anywhere on the bodywork or is it a no go? Dave. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 29, 2008 Author Share Posted August 29, 2008 Straight out through a hole in the rear crossmember takes some beating, whose was the V8 marine blue Series truck cab that came down here a few years back when we did a playday over near Taunton and a days laning? Beautiful thing it was...Will Yep that seems favorite option at the mo, and prob Drivers side as I have the Rear Hydro winch pipework and air release on the passenger side I have a 3.5inch cutter, I'll most prob take that with me, it will take a while to holesaw through 6mm plate Will wait till the day just in case matey has better ideas ............. Nige Quote Link to comment Share on other sites More sharing options...
Daan Posted August 29, 2008 Share Posted August 29, 2008 Yep that seems favorite option at the mo, and prob Drivers side as I have the Rear Hydro winch pipework and air release on the passenger sideI have a 3.5inch cutter, I'll most prob take that with me, it will take a while to holesaw through 6mm plate Will wait till the day just in case matey has better ideas ............. Nige I used to have mine through the hole in the crossmember, but decided against it later, because of exhaustfumes getting sucked in the cab trough the rr door while driving on motorwayspeeds. I always used to feel very sick after a long trip on the road. Daan Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 29, 2008 Author Share Posted August 29, 2008 I used to have mine through the hole in the crossmember, but decided against it later, because of exhaustfumes getting sucked in the cab trough the rr door while driving on motorwayspeeds. I always used to feel very sick after a long trip on the road.Daan Even a hardtop ? ?? Nige Quote Link to comment Share on other sites More sharing options...
will_warne Posted August 29, 2008 Share Posted August 29, 2008 Nige, its a Land Rover - panel gaps are measured in miles not mm Quote Link to comment Share on other sites More sharing options...
missingsid Posted August 30, 2008 Share Posted August 30, 2008 I used to have mine through the hole in the crossmember, but decided against it later, because of exhaustfumes getting sucked in the cab trough the rr door while driving on motorwayspeeds. I always used to feel very sick after a long trip on the road.Daan I guess you should be OK if you fit good sealing stips? My S1 has thisroute for the exhaust with a S/T and I can't rollup the back now due to fumes. Even with a H/T the eddy currents will keep the fumes around the rear door at motorway speeds. If you have the front door windows open the air gets sucked out of the front door and it tries to suck the replacement air in through the rear. Any gaps around the rear will draw in the fumes as they are not being left behind but are drawn along with you. A good show of this was when I blew the Transfer Box on my Hydred H/T the rear was completely covered in the oil from the box. Hope this drivel helps some Have fun. Marc. Quote Link to comment Share on other sites More sharing options...
Daan Posted August 30, 2008 Share Posted August 30, 2008 Even a hardtop ? ??Nige Especially on a hardtop, there is a massive suction on the flat back of the hardtop, and the fumes look for anyway to get in. My sealing isnt great, but about average like most landys. I dont think your split rr door is doing you much favours in that respect. I thought I mention it to you before you spend your hard earned. I settled for this: The exit is actually the swaged end of a TDI pipe, welded straight on a def 90 rr silencer which sits behind th rr wheel. The finisher is a bit of 18SWG stainless steel with a 3" (i think) swage and then cut out round and some rivetholes added. All home grown, as usual. daan Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 30, 2008 Author Share Posted August 30, 2008 Hmmm Thanks Daan I am still thinking re the rear crossmember, how about if over the top I welded a sort of Traffic light styllee cover, would this stop the gasses at all ? Nige Quote Link to comment Share on other sites More sharing options...
white90 Posted August 30, 2008 Share Posted August 30, 2008 Nope they'd be sucked in Likes Daans would be favourite Quote Link to comment Share on other sites More sharing options...
Keith Keir Posted August 31, 2008 Share Posted August 31, 2008 This is what you need its on a mates land rover Quote Link to comment Share on other sites More sharing options...
Guest noggy Posted August 31, 2008 Share Posted August 31, 2008 ive always fancied a big chrome stack behind my truck cab, it would look sweet. Quote Link to comment Share on other sites More sharing options...
