k9unit Posted August 29, 2008 Share Posted August 29, 2008 300 tdi if i disconnect the battery for 3 mins will it reset the ecu paul Quote Link to comment Share on other sites More sharing options...
PEASEY Posted August 29, 2008 Share Posted August 29, 2008 I could be wrong here but i dont think they have one my one has not got one unless you are talking about the window lift ecu? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 29, 2008 Share Posted August 29, 2008 Some 300TDi's do, some don't. The usual one is to disconnect it overnight. I'm not familiar with the TDi's but 3-5mins should be enough if it doesn't have too much internal backup. Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted August 29, 2008 Share Posted August 29, 2008 I could be wrong here but i dont think they have one my one has not got one unless you are talking about the window lift ecu? Generally speaking 300TDI Auto's from 1996 on will have an engine ecu. It is located behind the drivers side kick panel. Easy way to tell if yours has one is to look under the bonnet at the pipe from the airbox to the turbo if it has an airflow meter it will have an ECU. Pete. Quote Link to comment Share on other sites More sharing options...
PEASEY Posted August 29, 2008 Share Posted August 29, 2008 I stand corrected,mines a 94 m plate so thats why i couldnt find one.Sorry if i lead you up the wrong path there mate. Quote Link to comment Share on other sites More sharing options...
