way too deep Posted August 29, 2008 Share Posted August 29, 2008 i put another gearbox in my disco and took it out for a test drive and when i slow down coming to a halt it seems as if the gears are still engaged..even if i put it in neutral and coast for the last few yards there is a horrible juddering thru the box that continues even when fully stopped maybe 10 to 15 seconds afterwards...the gearbox was performing ok in the previous disco,,the only extra job i did was change the hand brake assembly and new rear output shaft seal...anyone have any ideas what is going wrong ..thanks robbie Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 29, 2008 Share Posted August 29, 2008 99% sure your handbrake is too tight and binding on a high spot on the drum this gives a horrible banging noise on deceleration exactly as described. Back off the adjuster a bit and see what happens Quote Link to comment Share on other sites More sharing options...
way too deep Posted August 30, 2008 Author Share Posted August 30, 2008 thanks mate ,will give it a try Quote Link to comment Share on other sites More sharing options...
