61a Posted August 30, 2008 Share Posted August 30, 2008 Has anyone out there had to change the front output shaft seal. Mine is leaking on the drive !!! I can find plenty of info on the rear one but nothing on the front one. I can't imagine its too bad a job but it would nice to know what to expect. Jules Quote Link to comment Share on other sites More sharing options...
cipx2 Posted August 30, 2008 Share Posted August 30, 2008 Chances are the bearing behind it is on his way out as well. This thread shows how to replace them both: http://forums.lr4x4.com/index.php?showtopic=25053 Quote Link to comment Share on other sites More sharing options...
61a Posted August 30, 2008 Author Share Posted August 30, 2008 Chances are the bearing behind it is on his way out as well.This thread shows how to replace them both: http://forums.lr4x4.com/index.php?showtopic=25053 Thanks for your quick reply I knew there must be some info on it somewhere Jules Quote Link to comment Share on other sites More sharing options...
sealt Posted August 30, 2008 Share Posted August 30, 2008 Havent replaced it myself but asume its the same as with the other oil seals on the driveline. Clean the area youre working on. Off with the propshaft and flange. Inspect the flange for wear. Out with the old one. In with the new one Put some grease on the new oilseal and flange and put it back Put some gasket sealent onto the flange to prevent leaks trough splines and on with the washer and tighten it up And mount the propshaft and done Quote Link to comment Share on other sites More sharing options...
First_Fleet Posted August 31, 2008 Share Posted August 31, 2008 Blimey! You make it sound sooooo easy. Quote Link to comment Share on other sites More sharing options...
