Turbocharger Posted September 11, 2006 Share Posted September 11, 2006 So to change the speedo gear, you grab hold of the lower rim of the part on the right with pliers or similar (which sticks proud of the t-box?) and pull? Sounds easy enough, maybe I will get round to sorting my speedo out. Quote Link to comment Share on other sites More sharing options...
Disco_Dunk Posted September 11, 2006 Share Posted September 11, 2006 Yep..... or you can just yank on the shaft of the gear - the housing is only held in place by the o-ring, so a gentle application of brute force can fetch both out in one go...... So to change the speedo gear, you grab hold of the lower rim of the part on the right with pliers or similar (which sticks proud of the t-box?) and pull? Sounds easy enough, maybe I will get round to sorting my speedo out. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 11, 2006 Author Share Posted September 11, 2006 I used a small flatblade screwdriver under each side and just wiggled it out. The one in my 90 was quite a tight fit, I don't think you'd have shifted it with a pair of pliers. Quote Link to comment Share on other sites More sharing options...
