karamac Posted August 30, 2008 Share Posted August 30, 2008 Hello All I had water `peeing` from the hole underneath the water pump on my 86 110 so removed and dismantled it by pulling off the impeller and pushing out the shaft. The seal next to the impeller is `goosed` but everthing else is OK. Does anyone know if the seal is available separately and where from please. Thanks ! Cheers, Chic. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 31, 2008 Share Posted August 31, 2008 I don't think you can buy water pump components seperately, although I rebuilt a S2A one once. A new pump is quite cheap anyway. Les. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted August 31, 2008 Share Posted August 31, 2008 According to LR the waterpump is a non serviceable item. As Les says, they're not expensive so I would replace the whole lot. worth it for the piece of mind that come with it. If you could just replace the seal you have no guarantee that the cause of the seal failure wont lunch the new seal in double quick time either.... Quote Link to comment Share on other sites More sharing options...
