Cyberfarmer Posted September 6, 2008 Share Posted September 6, 2008 Hi to all! I have a Td4 and I just encountered an electrical problem today apparently I havent been using it for a while and today I just found out that 1. TC,ABS,HILL DECENT and HANDBRAKE Warning Lights are ON I tried removing the HILL DECENT relay but still the light was ON The vehicle has normal braking power and no change at all 2.Speedometer doesn't work....but it used too the last time and all indicators are working including tachometer too 3. The aircon compressor not working OK the A/C is quite weird, I had it checked with a shop here coz I thought there was a leak but they couldn't find one and the freon charge was full. They tried directly switching the compressor through the positive line and it worked. I opened the relay (engine compartment box) and tried pressing the contact point and the compressor turned on. It seems the relay had no signal to switch it on. 4. Immobilzer not working I couldnt find any possible things to check. Please help. Quote Link to comment Share on other sites More sharing options...
