Power Steering confusion
Hi
I have 1989 Land Rover 90, It has a 300tdi conversion with R380 box.
My power steering leaking which I am going to replace. It is the original 6 bolt type. Does anybody know if this can be replaced directly with a 4 bolt type. I also believe there is a difference between a 4 bolt and a TD5 4 bolt, is this true. Any help would be great
What about the linkage then? as in from the steering wheel through the metal rods and uj's.... which connect it all.. will they be different?
4 and 6 bolt use the same fittings - interchangeable. It's the 3 bolt that won't work.
The 4 bolt PAS boxes are generally regarded as tougher units...
