crazyfarmerboy Posted September 9, 2008 Share Posted September 9, 2008 hello i have a diahatsu engine gearbox and transfer box. i have been told all of these will fit straight in. The transfer box has a lever for High neutral and low if this helps. The engine is a 2.8 turbo and it is in a 1987 fourtrak. thanks. will i need to be making any changes to my 110 like cutting footwell etc. i am guessing i need to make new mounts thank you. Quote Link to comment Share on other sites More sharing options...
ChrisV8 Posted September 9, 2008 Share Posted September 9, 2008 Have a look on the Conversion and Precision site, they do a kit of bits to put the engine in. Daughter has a Rangie with that engine works fine uses a conversion plate onto standard LR gearbox. seems on a 110 you have to mod the passenger footwell. http://www.engineconversions.co.uk/fitting_dai.html Quote Link to comment Share on other sites More sharing options...
