jacks906 Posted September 13, 2008 Share Posted September 13, 2008 hi all well just going to re wire me sankey narrow track and pop on full 12v system instead of the 24v so before i rip an snip all the old stuff off is it worth anything to anyone got all the lights glass lenses not the best (tab missing) the big plug everythin really cabling etc let me know before i start snipping dave Quote Link to comment Share on other sites More sharing options...
101sean Posted September 13, 2008 Share Posted September 13, 2008 Errr, why do you need to snip anything, just swap the bulbs If wiring for civvy socket, just plumb in to junction box and leave NATO wiring in place Quote Link to comment Share on other sites More sharing options...
Matt Neale Posted September 14, 2008 Share Posted September 14, 2008 Errr, why do you need to snip anything, just swap the bulbs If wiring for civvy socket, just plumb in to junction box and leave NATO wiring in place Or do what I did and just change the 12 pin military plug for a 7 pin civvy plug (and then swap the bulbs for 12 volt ones...!) Wires are as follows: [Pin A] = wire #1 = Convoy = not used on 12N [Pin B] = wire #2 = Stop = Pin 6 / Red [Pin C] = wire #3 = Convoy = not used on 12N [Pin D] = wire #4 = Earth = Pin 3 / White [Pin E] = wire #5 = Tail = Pin 5 (RH Tail/Brown) & Pin 7 (LH Tail / Black) [Pin F] = wire #6 = Fog = Pin 2 / Blue [Pin H] = wire #7 = Convoy = Not used on 12N [Pin J] = wire #8 = Stop = Pin 6 / Red [Pin K] = wire #9 = Aux = Not used on 12N [Pin L] = wire #10 = Earth = Pin 3 / White [Pin M] = wire #11 = LH Indicator = Pin 1 / Yellow [Pin N] = wire #12 = RH Indicator = Pin 4 / Green I've had a couple of Sankey type trailers and done this with them all. The mil spec wiring is a lot better than the aftermarket civvy stuff - I'd be inclined to hang onto it. Matt Quote Link to comment Share on other sites More sharing options...
jason110 Posted December 3, 2008 Share Posted December 3, 2008 hello, ive got 2 sankeys, are they all 24v spec? they both have the original NATO hitch. is there any way i can tell ? thanks in advance jason Quote Link to comment Share on other sites More sharing options...
Lars L Posted December 4, 2008 Share Posted December 4, 2008 Check what's stated on the bulbs. If it lacks all of them, just buy new in whatever voltage you like. Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted December 4, 2008 Share Posted December 4, 2008 If you look at the base of the buld it will state all sorts of info. 2 bits being the voltage and the wattage. Both bits which are important to you Quote Link to comment Share on other sites More sharing options...
jason110 Posted December 4, 2008 Share Posted December 4, 2008 thanks, sorry to hijack the thread Quote Link to comment Share on other sites More sharing options...
steffUK Posted December 8, 2008 Share Posted December 8, 2008 Would this adapter from 13 pin to 7 pin work as well? I'm not sure if the "european" 13pin is the same as the military 13 pin? cheers stef Towsure: 13-pin to 7-pin Adapter E604 Adapter for towing a caravan wired with a single 13-pin Euro-style plug, with a vehicle fitted with UK spec 12N and 12S Sockets Quote Link to comment Share on other sites More sharing options...
Lars L Posted December 8, 2008 Share Posted December 8, 2008 If my memory isn't playing up, I think the military plug has 12 pins... Several yaers since I changed the whole shabang to a civvy 7-pin plug. Quote Link to comment Share on other sites More sharing options...
101sean Posted December 8, 2008 Share Posted December 8, 2008 No, won't work, that's a different animal entirely and as Lars says, NATO is 12 pin. Quote Link to comment Share on other sites More sharing options...
LRjp Posted November 29, 2021 Share Posted November 29, 2021 can someone supply a link to sankey narrow track rear bulbs, lights indicators rear plate etc? i have no idead which ones to fit as it came with none to begin with! Quote Link to comment Share on other sites More sharing options...
