Harrod Posted September 20, 2008 Share Posted September 20, 2008 Having got the box out of the donor RRC to go into my 110 i find its an LT77 whith all the bellhousings etc for the 300TDi. If i put it back in am i going to have trouble with the ratios, and end up screaming the nuts off it at 65MPH? Would you suggest that finding an R380 box with 300TDi bellhousings would be a better bet and does anyone have one please!?!? Cheers, Dave Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted September 20, 2008 Share Posted September 20, 2008 The main gearbox won't make that much difference to the overall drivability (as in "engine revs"), a slight difference, but not much. It's the transfer box that does that, as long as you keep the same one fitted (or one of a same ratio) then all will be well. Quote Link to comment Share on other sites More sharing options...
Harrod Posted September 20, 2008 Author Share Posted September 20, 2008 ok cool. Will the one on the box from the RRC be ok to use then? Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted September 20, 2008 Share Posted September 20, 2008 if you've got the lt77 put it in you'll find it no slower gearing wise there not much diffrent Quote Link to comment Share on other sites More sharing options...
