JST Posted September 26, 2008 Share Posted September 26, 2008 Vehicle has a broken rear caliper mounting. the caliper failed around the top mounting bolt, bottom edge of. So could TC be the cause of it? Just speculating really as i am not sure what caused the caliper to fail. It became apparent on a 'normal' track drive but approx 3 days early the vehicle had been heavily bogged in to its axles and some gusto was applied in fwd and rev to try and extract it before a recovery vehicle could be found. On the track drive reversing; squealing from rear and on inspection rear caliper had departed and pivoted on the bottom caliper bolt. showing the top to have failed. I have not heard of this happening (regularly - ie outside of challenge events and serious off road) and wondered if it was a common occurrence. the damage did not occur from debris that i am certain of! - it got stuck in silt on the previous 3 days Those that know me will believe me when i say i wasnt driving as i rarely venture off road!!! (had to get it in before Walfy did!) Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted September 26, 2008 Share Posted September 26, 2008 I'm saying nothing . For a change. So are you after a new caliper now or do you have stock. I may have calipers in the shed but not sure if I have any that would fit yours. It hasn't moved in years so that puts it about pre modern age motoring Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted September 26, 2008 Share Posted September 26, 2008 How the hell can you blame Tony for a broken caliper - was he driving? Quote Link to comment Share on other sites More sharing options...
JST Posted September 26, 2008 Author Share Posted September 26, 2008 Sorry David, when i say TC for those not quite so geeky as Walfy to understand it i mean Traction Control. Mark - not mine, ones too old and doesnt move the other doesnt have it as too ££££ Quote Link to comment Share on other sites More sharing options...
TJ101 Posted September 26, 2008 Share Posted September 26, 2008 So, what vehicle was it one ?? A Discovery by chance ?? Only ever riped one caliper off, and that was down to me, and a handbrake Quote Link to comment Share on other sites More sharing options...
JST Posted September 27, 2008 Author Share Posted September 27, 2008 Defender Quote Link to comment Share on other sites More sharing options...
TJ101 Posted September 27, 2008 Share Posted September 27, 2008 Defender Mmm, if it had been a LR2, could understand,, they ain't Walfy proof Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted September 27, 2008 Share Posted September 27, 2008 Tim You pre heated it for me Quote Link to comment Share on other sites More sharing options...
DSN Posted September 29, 2008 Share Posted September 29, 2008 I broke the top lug on one of my front calipers a few years ago although luckily during testing brakes on the driveway so not so dangerous when funny noise and soggy pedal as the fluid leaked out. No traction control but probably an age thing. Quote Link to comment Share on other sites More sharing options...
white90 Posted September 29, 2008 Share Posted September 29, 2008 I'd wager it was hit by something TC(not me) wouldn't break the caliper otherwise there'd be a long list of people suffering from that. in the bog you mention a log/rock hit it, that's what broke mine Quote Link to comment Share on other sites More sharing options...
ciderman Posted September 29, 2008 Share Posted September 29, 2008 TC(not me) wouldn't break the caliper otherwise there'd be a long list of people suffering from that.in the bog you mention a log/rock hit it, that's what broke mine What you mean "Girling Bog" I lost 2 in there now , I put it down to the open spokes on the Mach 5` but not so the case . Quote Link to comment Share on other sites More sharing options...
roybatty666 Posted September 29, 2008 Share Posted September 29, 2008 My mate bust his in the same place on his Disco, he also got bogged on his tod and gave it some beans trying to get out, it seems the wheel/disc manage to catch a stone which slammed into the caliper busting the mount. I would think the TC operating would be causing less stress on the caliper than when under heavy braking Quote Link to comment Share on other sites More sharing options...
GBMUD Posted September 29, 2008 Share Posted September 29, 2008 I had a similar event where a piece of Slindon flint suspended in Slindon mud got caught in the wheel, rotated with the mud etc till it reached a suspension component and then rotated and punctured a hole in the inside of the wheel rim. The only puncture I have suffered where the repair needed a welder. Chris Quote Link to comment Share on other sites More sharing options...
roybatty666 Posted September 29, 2008 Share Posted September 29, 2008 I had a similar event where a piece of Slindon flint suspended in Slindon mud got caught in the wheel, rotated with the mud etc till it reached a suspension component and then rotated and punctured a hole in the inside of the wheel rim. The only puncture I have suffered where the repair needed a welder. Chris Funnily enough my mates broken caliper moment also holed his alloy at the same time Spinning is bad mmkay Quote Link to comment Share on other sites More sharing options...
JST Posted September 30, 2008 Author Share Posted September 30, 2008 maybe it was a rock or similar, certainly no evidence to the inside of the alloy though. i was just surprised how it broke considering the tame conditions it was working in and thought TC may have something to do with it as it does brake on and off quite hard. Quote Link to comment Share on other sites More sharing options...
