sparg Posted September 29, 2008 Share Posted September 29, 2008 Hi, without the front spat/wheelarch on a newish 90, there's a gap between inner and outer wings. I've found this out after a recent inadvertent body modification. I need to fit a new outer. But, my question is - is there likely to be a water ingress problem until I've fixed it? - wiring for lights, hooter, etc anything else? Also, those little plastic poppers that hold the spat in place - when ordering them - what are they called?. Finally, the plastic spat has actually torn just those innermost holes that fasten to the inner. Suggestions? new spat or can be repaired? Quote Link to comment Share on other sites More sharing options...
yellow Posted September 29, 2008 Share Posted September 29, 2008 I refitted the spats by drilling some pilot holes and using self-tapping screws. Simple and fast. As for water ingress... I drove without the spats for a month or two this summer. Had no issues... Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted September 29, 2008 Share Posted September 29, 2008 You'll get water spray up inside the wing though, and obviously onto the back of the lights. Quote Link to comment Share on other sites More sharing options...
western Posted September 29, 2008 Share Posted September 29, 2008 plus the tyre tread won't be covered & is therefore illegal on UK roads. Quote Link to comment Share on other sites More sharing options...
sparg Posted September 29, 2008 Author Share Posted September 29, 2008 plus the tyre tread won't be covered & is therefore illegal on UK roads. wondered about that - strictly, with ordinary tyres (235 x 85), the tread doesn't protrude when the wheel is straight - what are the regs, anyone? Quote Link to comment Share on other sites More sharing options...
western Posted September 29, 2008 Share Posted September 29, 2008 when viewed from directly above the tread width should be covered by bodywork or wheel arch. Quote Link to comment Share on other sites More sharing options...
sparg Posted September 29, 2008 Author Share Posted September 29, 2008 when viewed from directly above the tread width should be covered by bodywork or wheel arch. ah -given the state of the wing, a teeny bit of applied force should suffice, for now Quote Link to comment Share on other sites More sharing options...
