2nd Alternator on 300tdi
Harrod
Greetings!
I've just fabricated a bracket to allow a second alternator to sit where the Air Con pump would sit. I now have a few Q's!!!
I'm using a lucas alternator from a 2.5 NA block, however this has a thin V type belt pulley. Does anyone know what type of pulley(P/N Please!) to allow me to use the second belt space from the crank, the one at the rear. Also what belt should i use?
Is there anything that you guys in your experience would do with this setup that i may not have thought of?
Thanks!!!
