wyllie Posted September 29, 2008 Share Posted September 29, 2008 Any one know the part numbers for diifflock linkage on lt77/lt230 combination. 'Bent rod' between main pivot link down side of gearboxand quadrant on selector shaft in transfer box has broken so I need to find one. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted September 29, 2008 Share Posted September 29, 2008 There are several types. one is a "cast" item, very expensive! part # FRC7315 and £126.18!!! (Early type) to VIN LA939976 4 cylinder suffix 22D t/box then there's the "bent piece of flat bar" type: FTC4095 £5.59 from VIN MA939976 and the "piece of wider flat bar bent over into a C shaped channel" type, FRC8204 £30.36, from VIN LA939975 Quote Link to comment Share on other sites More sharing options...
wyllie Posted September 30, 2008 Author Share Posted September 30, 2008 Thanks for the reply, its the cast type. THe broken part is made from round material and fits to the bottom of the main pivot lever (not shown on the drawing) Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted September 30, 2008 Share Posted September 30, 2008 Ah, this one then? Part # 14 the cast link, is FRC7315 # 13, the bracket, is FRC6066 Quote Link to comment Share on other sites More sharing options...
paul stage1v8 Posted September 30, 2008 Share Posted September 30, 2008 I think he is talking about the link which comes off the bottom of #14 onto the operating lever from the box, the u shaped piece? Quote Link to comment Share on other sites More sharing options...
western Posted September 30, 2008 Share Posted September 30, 2008 might be item 16 on this diagram Quote Link to comment Share on other sites More sharing options...
wyllie Posted September 30, 2008 Author Share Posted September 30, 2008 Thanks Western, you have the right part, but my gearbox is pre 1987, my connecting link has the legs at 90 degrees - see photo I think I've put the photo on twice, its my first attempt Quote Link to comment Share on other sites More sharing options...
western Posted September 30, 2008 Share Posted September 30, 2008 there's 2 part numbers for that link bar in the list on the diagram above, FRC8544 or FTC3698 check the note 1 & 2 & the transfer box serial number,that will tell you which bar you need. also on the LT230 TB parts page when fitted to LT85 gearbox, it shows FRC7948 which is exactly what your photo shows so it's most likely that one. Quote Link to comment Share on other sites More sharing options...
wyllie Posted September 30, 2008 Author Share Posted September 30, 2008 Many thanks, will ring around to try & find FRC7948. Maybe Land Rover used the same connecting link on early 90's as on the LT85. Your efforts appreciated Quote Link to comment Share on other sites More sharing options...
western Posted September 30, 2008 Share Posted September 30, 2008 good luck, hope you find one. Quote Link to comment Share on other sites More sharing options...
smacsor Posted October 1, 2008 Share Posted October 1, 2008 I replaced exactly the same part a couple of weeks ago!! It's FRC7652 and I paid £8.10 plus VAT from local Main Stealer. Simon Quote Link to comment Share on other sites More sharing options...
wyllie Posted October 1, 2008 Author Share Posted October 1, 2008 Thanks Simon, £8.10 plus VAT - a bargain for a piece of bent 6mm rod!!!! Jim Wyllie Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted October 1, 2008 Share Posted October 1, 2008 I've got one in the garage (on another t/box) which is the bent rod, but in an upside down "U" shape, if thats any good? the above pic looks like it's "U" shaped but with one end turned through 90 degrees? if the "U" shaped one is any good, you can have it mate. PM me your addy. Quote Link to comment Share on other sites More sharing options...
Edd80inch Posted October 1, 2008 Share Posted October 1, 2008 Mine broke (V8 90)due to lack of use by the prvious owner, and my trying to put it into difflock. I Just made my own out of a bit of bar. Esay enough if you cant find one. Edd Quote Link to comment Share on other sites More sharing options...
wyllie Posted October 2, 2008 Author Share Posted October 2, 2008 Diesel Jim, it has legs at 90 degrees, thanks anyway Ed80inch, local main dealer is checking availability, if no joy then I bend & drill some bar Quote Link to comment Share on other sites More sharing options...
