300tdi into RRC?
RILEY
Hi everyone not sure if its been done to death but here goes Will a 300tdi fitted with an auto box from a disco go into a rrc want the engine not the box obviously needs a flywheel and such but here's the thing will it bolt to the lt77 g/box any other pitfalls pointed out would be greatly appr RRC a 1990 2.5 vm diesel CHEERS
Well......I know that a 300TDi bolts to an LT77 box in a Discovery with not mods (other than the automatic to manual changes that you have pointed out). I would think that this would also be the case in a RRC.
Both the LT77 and R380 boxes from Discoverys are getting cheap now so buying one to suit shouldn't break the bank.
IIRC there is some electronics on the injector pump on the 300TDi in automatic form.
So all considered might be worth starting with a 300TDi manual with a gearbox as a complete unit.
HTH
