kenyan-rover Posted September 30, 2008 Share Posted September 30, 2008 I own an 88 series2a. The turning isn't that great on it so i was wondering if there was a way of improving that without having to change tyre sizes.. Any help on this would be much appreciated.. Quote Link to comment Share on other sites More sharing options...
sotal Posted September 30, 2008 Share Posted September 30, 2008 Check that your steering stops aren't set too far out. If they are wind them in checking to make sure your wheels don't hit the springs as you go. With standard wheels you can wind them more or less all the way in. There is also different rims which give different offset which can change the turning circle Quote Link to comment Share on other sites More sharing options...
kenyan-rover Posted October 2, 2008 Author Share Posted October 2, 2008 Check that your steering stops aren't set too far out. If they are wind them in checking to make sure your wheels don't hit the springs as you go.With standard wheels you can wind them more or less all the way in. There is also different rims which give different offset which can change the turning circle Thanx for the advice much appreciated Quote Link to comment Share on other sites More sharing options...
