chucknorris666 Posted October 2, 2008 Share Posted October 2, 2008 Hi guys i was wundering if some of you freelander owners could help me i have got some spare time on my hands so i am going to give my freelander a good service, i have a V 2000 reg freelander 2.0 L series engine 5 door station wagon. I am going to do a complete oil chance on everything Gearbox Final Drive TRDV Engine Power Stearing I was just wundering if you guys could tell me the corect grade oils to use for each of them and also the capacity for each one so i know how much of each tipe of oil i need to buy. any help would be much apriciated. I am also in the middel of doing all the belts and cooling system and replaceing the brive shaft covers and stuff to but its the oil im rely stuck with. Quote Link to comment Share on other sites More sharing options...
WESTENDER Posted October 3, 2008 Share Posted October 3, 2008 Hi guys i was wundering if some of you freelander owners could help me i have got some spare time on my hands so i am going to give my freelander a good service, i have a V 2000 reg freelander 2.0 L series engine 5 door station wagon.I am going to do a complete oil chance on everything Gearbox Final Drive TRDV Engine Power Stearing I was just wundering if you guys could tell me the corect grade oils to use for each of them and also the capacity for each one so i know how much of each tipe of oil i need to buy. any help would be much apriciated. I am also in the middel of doing all the belts and cooling system and replaceing the brive shaft covers and stuff to but its the oil im rely stuck with. chucknorris666 Sorry about the slow answer, if it still relevant this is a list of oils for the Freelander= ENGINE OIL =10w/40 or 15w/40 to ACEA A3 or ACEA B3 4.5 litres inc of filter GEARBOX [man] =Texaco MTF94 or Burmah MTF1067 if just topping up use engine oil 10w/40 to spec ACEA A2 GEARBOX [auto] =Texaco N402 IRD =Texaco S575W/90 tospecAPI GL5 DIFF =Texaco multigear t80W/90 ETL 7441 to spec API GL5 Power steering = ATF to Dexron11d or 111 unable to give you capacities for transmission as they are not quoted in my manual, as i said sorry for the slow reply hope this helps Quote Link to comment Share on other sites More sharing options...
WESTENDER Posted October 3, 2008 Share Posted October 3, 2008 chucknorris666 Sorry about the slow answer, if it still relevant this is a list of oils for the Freelander= ENGINE OIL =10w/40 or 15w/40 to ACEA A3 or ACEA B3 4.5 litres inc of filter GEARBOX [man] =Texaco MTF94 or Burmah MTF1067 if just topping up use engine oil 10w/40 to spec ACEA A2 GEARBOX [auto] =Texaco N402 IRD =Texaco S575W/90 tospecAPI GL5 DIFF =Texaco multigear t80W/90 ETL 7441 to spec API GL5 Power steering = ATF to Dexron11d or 111 unable to give you capacities for transmission as they are not quoted in my manual, as i said sorry for the slow reply hope this helps Whoops sorry, it does give capacities as follows =IRD =1.1L G/BOX from dry =2.2L diff =0.83L Quote Link to comment Share on other sites More sharing options...
chucknorris666 Posted October 6, 2008 Author Share Posted October 6, 2008 thanks mate your a life saver i have not got a handbook you see, freelanders got no service history what so eva so im going to chance all oils and colent and stuff to be on safe side, then when i save up enuf cash get a specialist to change the cam belt as im not daring enuf to do that myself incase i nacker the engine up lol Quote Link to comment Share on other sites More sharing options...
