alfredenewman Posted October 3, 2008 Share Posted October 3, 2008 is there a problem in welding the outer part of the drive flange to the new shaft annd new flange on a salibury axle ?i know the heat might alter the temper of the metal in the shaft and flange, but has any one done it.just wondering ????? Quote Link to comment Share on other sites More sharing options...
clbarclay Posted October 3, 2008 Share Posted October 3, 2008 Why? As you say the the heat will play merry hell with the metalergy of the parts as well as other potential probles such as fatigue craking around the weld. As a temporary bodge we wleded up some worn splines on a tractor. It worked, but not for long before the shaft just cracked through. Quote Link to comment Share on other sites More sharing options...
bluespanner Posted October 4, 2008 Share Posted October 4, 2008 Did it on my series 2, before it had Rangie axles. Worked fine. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted October 4, 2008 Share Posted October 4, 2008 First, you must use a TIG welder as the metals are different. Do not weld on the inside of the drive member as this will cause breakage. I have had welded half shafts on my 110 for years and so have many others here in SA. One company made a special jig that rotated at the correct speed to get a good weld. Autobox in Pretoria IIRC. I bought mine from Cliff Barker who used to race a 110 pickup with a BMW M3 engine and welded up centre diff and half shafts. He also ran a Detroit locker in the back, so the shafts got a bit of a pounding. He had FWH on the front for road use. Quote Link to comment Share on other sites More sharing options...
alfredenewman Posted October 4, 2008 Author Share Posted October 4, 2008 First, you must use a TIG welder as the metals are different. Do not weld on the inside of the drive member as this will cause breakage. I have had welded half shafts on my 110 for years and so have many others here in SA. One company made a special jig that rotated at the correct speed to get a good weld. Autobox in Pretoria IIRC. I bought mine from Cliff Barker who used to race a 110 pickup with a BMW M3 engine and welded up centre diff and half shafts. He also ran a Detroit locker in the back, so the shafts got a bit of a pounding. He had FWH on the front for road use. mines much the same detroit locker 4.5 je engine that has twisted shafts in the past but it says alot for salisbury that although they look like a cork screw[slight exageration] thy havent broken yet .inspecting the shafts has become as routine as dipping the oil ,its the flanges that give me the problem. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted October 4, 2008 Share Posted October 4, 2008 Yes, the flanges are much weaker than the shafts themselves, but when the flange strips it often damages the shaft. I'm glad I don't have the later 'wolf' type half-shafts, they seem to cost three times as much as the std Salisbury items. With a 300tdi I don't think I have the power to damage the shafts Quote Link to comment Share on other sites More sharing options...
Diff Posted October 4, 2008 Share Posted October 4, 2008 Welded up my flanges/shafts with a mig on my rear salisbury before my splines wore out. Welded all round on the outside and a couple of tacks on the inside. No problems, but make sure everything is perfectly straight. Regards, Diff Quote Link to comment Share on other sites More sharing options...
