tswhit Posted October 7, 2008 Share Posted October 7, 2008 Ok gents Im new to LR autos so be gentle with me, the problem is this: Will not pull away in 2,3 or D. Select 1, pull away and then select all the above and it drives fine, changing up and down the box as required. Stop at the lights and i need to select 1 again to get moving. Reverse is fine. Oil seems clean, I am like an old fuel tank.......BAFFLED! Quote Link to comment Share on other sites More sharing options...
andyb Posted October 7, 2008 Share Posted October 7, 2008 Sounds like a sprag clutch had gone. Don't think it will cause any damage to drive it, but a reckon a rebuild is on the cards. HTH Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted October 7, 2008 Share Posted October 7, 2008 Taken from the Ashcrofts website :- I have a 4sp ZF, when I select "D" the vehicle won't move, when I select "1" the vehicle moves off. I can then select "D" and continue to drive normally. If I stop I have to start in first again. Why? A sprag clutch has "inverted" and will need replacing. No further damage will occur if you continue to drive but you will need to select "1" every time to start moving. A rebuild is required to correct this. Pete. Quote Link to comment Share on other sites More sharing options...
andyb Posted October 7, 2008 Share Posted October 7, 2008 Wahoo I was right Quote Link to comment Share on other sites More sharing options...
