stuntman Posted October 7, 2008 Share Posted October 7, 2008 Hello one and all, can some one help with this at all? Is it possible to swap from electrical speedo to mechanical cable? If so how Thanks in advance Andi Quote Link to comment Share on other sites More sharing options...
western Posted October 7, 2008 Share Posted October 7, 2008 Yes, but why ? whats wrong with the electrionic speedo transducer as on Td5's & now in my '89 110. Quote Link to comment Share on other sites More sharing options...
western Posted October 7, 2008 Share Posted October 7, 2008 to fit a cable drive speedo, you'll need to obtain the speedo & drive cable. then swap those for the electronic transducer on the transfer box & swap the speedo in the instrument pack & secure the cable so it doesn't get snagged on anything. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted October 7, 2008 Share Posted October 7, 2008 Why would you want to do this? Personally as an owner of a mech speedo 110 I would go to the electrical version as it is more accurate, so it seems. Well, whatever floats your boat, I suppose. Quote Link to comment Share on other sites More sharing options...
JST Posted October 7, 2008 Share Posted October 7, 2008 it can be done as above, i am going the other way and will have a mechanical speedo available soon with the drive. Quote Link to comment Share on other sites More sharing options...
stuntman Posted October 7, 2008 Author Share Posted October 7, 2008 it can be done as above, i am going the other way and will have a mechanical speedo available soon with the drive. I have a mechanical speedo and a new speedo cable right here, however my gearbox is electrical drive. So do I just pull the electrical transducer off and replace it with the cable drive? Can I ask for an idiots guide to doing this As I'm having a bit of a simple moment Quote Link to comment Share on other sites More sharing options...
JST Posted October 7, 2008 Share Posted October 7, 2008 remove the transducer (10mm head IIRC) and replace with the speedo drive, you will need the little fork shaped tabed to hold the cable into the box. Quote Link to comment Share on other sites More sharing options...
western Posted October 7, 2008 Share Posted October 7, 2008 I have a mechanical speedo and a new speedo cable right here, however my gearbox is electrical drive.So do I just pull the electrical transducer off and replace it with the cable drive? Can I ask for an idiots guide to doing this As I'm having a bit of a simple moment dead easy even you can do it just as JST says, the U shaaped fork is LR part 533765, as it's a very old style number IIRC any cable driven speedo LR will have one. but I'd say it was a retro-grade step, whats wrong with the current lekky speedo/transducer ????? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 8, 2008 Share Posted October 8, 2008 You'll also need a hole in the bulkhead for the cable to pass through, if you don't already have one. Mo Quote Link to comment Share on other sites More sharing options...
paul stage1v8 Posted October 8, 2008 Share Posted October 8, 2008 I think he is fitting a disco box with a transducer to his early v8 110 so has all the bits, just the transducer is in the way. The transducer in my disco transfer was held on by an allen bolt. Quote Link to comment Share on other sites More sharing options...
stuntman Posted October 9, 2008 Author Share Posted October 9, 2008 I think he is fitting a disco box with a transducer to his early v8 110 so has all the bits, just the transducer is in the way.The transducer in my disco transfer was held on by an allen bolt. Well put Paul. that's what I meant Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 9, 2008 Share Posted October 9, 2008 Remove transducer, plug in cable, use clamp off old gearbox Mo Quote Link to comment Share on other sites More sharing options...
stuntman Posted October 9, 2008 Author Share Posted October 9, 2008 Ah, I have a square pin protruding out where the cable should plug in, I take then this is part of the transducer and can be removed, I've tried to get it out but t seemed to be wel stuck in, I'll resort to a little bit of hea then and try to get it out again. Thanks for all the replies Quote Link to comment Share on other sites More sharing options...
paul stage1v8 Posted October 9, 2008 Share Posted October 9, 2008 is it a solid sqare pin or a hollow one? if it is solid it shouldnt be there, but the piece the cable goes in is like a square tube, if you check your old box you will see it. Quote Link to comment Share on other sites More sharing options...
