stiff reverse gear
I seem to remember (from drowning an old 90 in a river :ph34r:) that something in the reverse can get seized up and cause issues, others might be able to throw more light on the problem (I didn't fix ours, somebody else did as it was years ago now)
cheers bogmonster, hopefully someone will shed some light on the situation
check the gear liver from top of the box
maybe needs some adjustment and check if there is alot of freeplay as the aluminum part get eaten from the sides
and again on top on the right there is the sping were holds the lever to stop maybe needs replace
sorry if cannot explane easier
