stuntman Posted October 11, 2008 Share Posted October 11, 2008 Hello one and all, can anyone help with a picture or two of where the seatbelt reel should sit, I have a CSW which was robbed of all the seatbelts before I got it. I'm coming to the end of a rebuild but the belts are causing some confusion as I'm struggling to find where the 2nd row of belts attach and anchor. Please help!!!!!! Thanks in advance Andi Quote Link to comment Share on other sites More sharing options...
Madcowz Posted October 11, 2008 Share Posted October 11, 2008 I popped out to take some pictures of mine. You can see them on http://landroveroneten.com/ The trim is covering the reel housing so you can't see that much. mad Quote Link to comment Share on other sites More sharing options...
stuntman Posted October 12, 2008 Author Share Posted October 12, 2008 That's fantastic mate, it explains alot! The only thing I need now is how it connects behind the trim I'll see if anyone else can help with this one!!! Thanks Mad Quote Link to comment Share on other sites More sharing options...
mrFrog Posted October 12, 2008 Share Posted October 12, 2008 How about this ? I happen to have two spare sides sitting in my workshop which I need to sell at some point. Here are a few pictures which hopefully will help. Let me know if you need more while I still have them Trying to give you an idea of where things screw/mount onto, think the belt screws into the top hole in the middle of the black panel, the bottom hole I think is for the inside panel to clip onto. This screw on the side is the other side of the nut on the picture above HTH, don't hesitate to ask for more Quote Link to comment Share on other sites More sharing options...
mrFrog Posted October 12, 2008 Share Posted October 12, 2008 Whoops, just realised (after re-reading your original post) you were after pictures of the reel fittings, so not sure how much use the ones I posted are... They are for the top bit through which the belt loops to reach over the passenger's shoulder. Quote Link to comment Share on other sites More sharing options...
new defender Posted February 16, 2009 Share Posted February 16, 2009 How about this ? I happen to have two spare sides sitting in my workshop which I need to sell at some point. Here are a few pictures which hopefully will help. Let me know if you need more while I still have them Trying to give you an idea of where things screw/mount onto, think the belt screws into the top hole in the middle of the black panel, the bottom hole I think is for the inside panel to clip onto. This screw on the side is the other side of the nut on the picture above HTH, don't hesitate to ask for more Hi, I've been looking for the top mounting brackets and noticed you had some (some time ago) just wondered if you still had them and wanted to sell them? Quote Link to comment Share on other sites More sharing options...
