BogMonster Posted October 18, 2008 Share Posted October 18, 2008 I have never seen one break like that either, usually the four rivet things that hold the whole thing together let go and the front and rear bits of the centre separate spraying springs and stuff all over the place. Abusive driver I reckon Quote Link to comment Share on other sites More sharing options...
western Posted October 18, 2008 Author Share Posted October 18, 2008 Not me I was half way to work when it went, in third travelling round a bend & climbing a short hill, Overdrive was disengaged so that can't be the cause. had a closer look at the friction plate outer ring, the thin metal part is actuaaly ripped out of the a section of friction material & the outer edge of part of it is damaged, as the crank spigot bush is totally broken up I'm thinking part of that has been wedged in the friction plate & caused the total failure. Quote Link to comment Share on other sites More sharing options...
RILEY Posted October 18, 2008 Share Posted October 18, 2008 VALEO say no more COPY MATERIAL cant beat BORG WARNER Quote Link to comment Share on other sites More sharing options...
RILEY Posted October 18, 2008 Share Posted October 18, 2008 MAKE that BORG and BECK Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 18, 2008 Share Posted October 18, 2008 Abusive driver I reckon Bluddy right - Chav! Les Quote Link to comment Share on other sites More sharing options...
western Posted October 18, 2008 Author Share Posted October 18, 2008 VALEO say no more COPY MATERIAL cant beat BORG WARNER Nope, Valeo is a OEM supplier to LR & Borg & Beck are now part of Delphi Quote Link to comment Share on other sites More sharing options...
western Posted October 18, 2008 Author Share Posted October 18, 2008 Bluddy right - Chav! Les :rofl: Quote Link to comment Share on other sites More sharing options...
western Posted October 22, 2008 Author Share Posted October 22, 2008 right got my nice shiny new parts today, already fitted the new spigot bush to the rear of the crank & the new release bearing onto the gearbox shaft. only 1 problem the new friction plate is not marked 'flywheel side' nore is there any info on or in the box to advise. I can't remember which it was on the old plate & my Defender workshop manual doesn't say either. so which side faces the flywheel pic 1 flat side or pic 2 sticky out side Quote Link to comment Share on other sites More sharing options...
mmgemini Posted October 22, 2008 Share Posted October 22, 2008 Flat side to flywheel. The sticky out bit fits into the pressure plate center. Try it and you'll see what I mean. Hey you're making me think. 1999 was the last time I did a clutch...... mike Quote Link to comment Share on other sites More sharing options...
western Posted October 22, 2008 Author Share Posted October 22, 2008 Thanks Mike, hope the thinking didn't hurt to much Quote Link to comment Share on other sites More sharing options...
ozzie1989 Posted October 24, 2008 Share Posted October 24, 2008 Good old traditional clutch eh The DMF on my TD5 is rubbish, very snatchy if you ask me though that could I suppose be the clutch! My fathers transit had a DMF, and had it replaced each year under warranty due to shuddering and noise in reverse and on rundown (regularly loaded to 3.5ton MWB MR) then Ford finally admitted defeat and brought out an official 'coversion' kit to convert it back to a normal flywheel/clutch configuration! Has lasted years now Thanks for the animation by the way, now I know how it really works! Quote Link to comment Share on other sites More sharing options...
western Posted October 24, 2008 Author Share Posted October 24, 2008 just a update. Cos I know your all dying to know how I'm getting on, well new clutch is fitted & so is the gearbox/transfer box assembly, chuffing heavy & awkward trying to move & line it up on your own with only 1 trolley jack/big bar/ratchet straps to hold it, got the shaft lined up OK & then used the studs/nuts to pull it together, all bolted up & some of the reconnections to transfer linkages done, tomorrow got to refit the mounts/floor plates/overdrive/props & a few other bits. should be able to complete the job tomorrow Quote Link to comment Share on other sites More sharing options...
upnover4x4 Posted October 24, 2008 Share Posted October 24, 2008 I had a clutch plate blow like that on a metro. The primary gear bronze bearing had gone eliptical causing the clutch to disintegrate. Turned out the primary gearbox bearing had wear in also which amplified the effect. Hope its nothing more than the clutch plate as wouldnt like to see you having to remove the box again. Did you check for excessive movement on the gbox input shaft bearings? Adrian Quote Link to comment Share on other sites More sharing options...
western Posted October 24, 2008 Author Share Posted October 24, 2008 Yep, main & transfer boxes are OK. Quote Link to comment Share on other sites More sharing options...
western Posted October 25, 2008 Author Share Posted October 25, 2008 Well the TB was till this morning see more busted intermediate gear Quote Link to comment Share on other sites More sharing options...
