Ivan Posted October 20, 2008 Share Posted October 20, 2008 I have a 1996 90. I have just changed the rear door on it but, the existing door handle is about to break (badly corroded). I have a spare door handle that I can swop over but, I don't have the keys for the lock. So I was hoping to swop the existing lock with the one on the spare. Any idea how I get the lock out without any keys ? TIA Ivan Quote Link to comment Share on other sites More sharing options...
western Posted October 20, 2008 Share Posted October 20, 2008 on the lock barrell tube should be a small pin, press this down & using the key extract the lock barrel. read this http://forums.lr4x4.com/index.php?showtopi...;hl=lock+barrel Quote Link to comment Share on other sites More sharing options...
roybatty666 Posted October 20, 2008 Share Posted October 20, 2008 Any idea how I get the lock out without any keys ? ... using the key extract the lock barrel. I see a problem Unless you can use any key? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted October 20, 2008 Share Posted October 20, 2008 Any key that will physically fit in the lock should do it. Quote Link to comment Share on other sites More sharing options...
western Posted October 20, 2008 Share Posted October 20, 2008 a small screwdriver should work, it's only to disengage the lock fingers so the barrel can slide out. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 20, 2008 Share Posted October 20, 2008 Ivan, it's a tiny hole and is normally full of crud and so easy to miss. Mo Quote Link to comment Share on other sites More sharing options...
Ivan Posted October 21, 2008 Author Share Posted October 21, 2008 Thanks for the responses guys. Will try and sort it at the weekend. Ivan Quote Link to comment Share on other sites More sharing options...
