robhybrid Posted January 24, 2006 Share Posted January 24, 2006 Does anyone know the part no for the throttle lever assembly that bolts to the top of the fuel pump on a 300 tdi. The lever has 4 holes in a row at one end and bolts to the throttle lever at the other end. This lever is what operates the kick down. Cheers Rob. Quote Link to comment Share on other sites More sharing options...
MogLite Posted January 24, 2006 Share Posted January 24, 2006 This one Rob ? ISTR I got the part number from Ashcrofts site Quote Link to comment Share on other sites More sharing options...
western Posted January 24, 2006 Share Posted January 24, 2006 This one Rob ? ISTR I got the part number from Ashcrofts site My EPC tells me that lever is ERR4897 in 2002 it was around 2.16 plus vat Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted January 24, 2006 Share Posted January 24, 2006 What difference does it make connecting the kick down cable to one of the 4 holes then? (I've got a Tdi autibox sat in the garage waiting to go into my 90!) Quote Link to comment Share on other sites More sharing options...
robhybrid Posted January 24, 2006 Author Share Posted January 24, 2006 My EPC tells me that lever is ERR4897 in 2002 it was around 2.16 plus vat Thanks western/moglite Just what I was looking for. Quote Link to comment Share on other sites More sharing options...
GBMUD Posted January 25, 2006 Share Posted January 25, 2006 What difference does it make connecting the kick down cable to one of the 4 holes then?(I've got a Tdi autibox sat in the garage waiting to go into my 90!) Depending on which hole you use will affect how much throttle you need to make it kick-down - closer or further from the pivot point - the further away from the spindle, the more the cable is pulled for any given increase in throttle setting and the sooner the kick-down. Chris Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted January 25, 2006 Share Posted January 25, 2006 Depending on which hole you use will affect how much throttle you need to make it kick-down - closer or further from the pivot point - the further away from the spindle, the more the cable is pulled for any given increase in throttle setting and the sooner the kick-down.Chris Ahhh.... so, say for example, you've got a nice torqey 2.8 TGV then you could set it to kick down with a small amount of throttle, and if you have an asthmatic 2.5 NA diesel then you'd set it to kick down with more revs? and i suppose it's personal driving preferance too? Quote Link to comment Share on other sites More sharing options...
GBMUD Posted January 25, 2006 Share Posted January 25, 2006 I am guessing that the 2.5 might need to kick-down a little sooner than the TGV... Chris Quote Link to comment Share on other sites More sharing options...
