jason_landy99 Posted October 25, 2008 Share Posted October 25, 2008 i have the chance to get a rear 101 axel for my disco challenge truck build just wanna no how much are thay are worth Quote Link to comment Share on other sites More sharing options...
6cyltdi Posted October 25, 2008 Share Posted October 25, 2008 What axle are you planning running on the front....? Quote Link to comment Share on other sites More sharing options...
callum Posted October 25, 2008 Share Posted October 25, 2008 depends if you can get the front one too. as they're different width and different stud pattern to normal rover axles Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 25, 2008 Share Posted October 25, 2008 Different ratio as well aren't they....? 5.33:1 or something.... Quote Link to comment Share on other sites More sharing options...
jason_landy99 Posted October 25, 2008 Author Share Posted October 25, 2008 What axle are you planning running on the front....? will be a 101 on the front Quote Link to comment Share on other sites More sharing options...
will_warne Posted October 26, 2008 Share Posted October 26, 2008 From the top - you will gain about 3" in track (not necessarily a problem but something to think about), the bolt pattern for the wheels is different (6 bolt NATO pattern same as a Mog), drum brakes and the only disc conversion is meant to be a pig to fit and is made by Zeus (of timing gear fame) so will probably be badly built. However, the internals are very strong. If you want to fit lockers you have to get special spider gears as the spline count is a little odd (23 IIRC). The best bit about the front axle is the size of the CVs - they are massive! One potential issue they do have, though, is that the swivels are welded to the axle tubes so yo need to find an axle with good swivels. As has been said the diff ratio is pretty low (may be a good thing) but other D60 / Salisbury ratios will fit so you could run 3.54 or 4.7 easily. Bathtub Pete used 101 axles for a while and seemed to get on well with them..... Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted October 26, 2008 Share Posted October 26, 2008 They are 5.57:1 ratio, and on 27 spline shafts. Rakeway does a conversion to dana 60 arb's with custom 300m 1 1/2" dia 35 spline shafts Quote Link to comment Share on other sites More sharing options...
