slamfire Posted October 26, 2008 Share Posted October 26, 2008 I have a PRC2734 ignition switch to fit a 110 ex-Army, the switch is numbered 1 to 5, does anyone know what colour wire goes to which terminal on the switch ??? Thanks http://www.lucaselectrical.co.uk/technical/SwitchgearTI.pdf might help & http://forums.lr4x4.com/index.php?showtopi...+starter+switch refer to the lucas extract switch number 35288 terminal numbers are 1 = 12v feed 2 = FSO [fuel shut-off ] 3 = Starter 4 = auxilary 5 = heater plugs Quote Link to comment Share on other sites More sharing options...
Lars L Posted October 27, 2008 Share Posted October 27, 2008 1 brown 2 white/black (two wires on the diagram) 3 white/red 4 white 5 brown/red If you have stated the various functions as they should be... Quote Link to comment Share on other sites More sharing options...
slamfire Posted October 27, 2008 Author Share Posted October 27, 2008 I have a PRC2734 ignition switch to fit a 110 ex-Army, the switch is numbered 1 to 5, does anyone know what colour wire goes to which terminal on the switch ??? Thankshttp://www.lucaselectrical.co.uk/technical/SwitchgearTI.pdf might help & http://forums.lr4x4.com/index.php?showtopi...+starter+switch refer to the lucas extract switch number 35288 terminal numbers are 1 = 12v feed 2 = FSO [fuel shut-off ] 3 = Starter 4 = auxilary 5 = heater plugs many thanx Quote Link to comment Share on other sites More sharing options...
western Posted October 27, 2008 Share Posted October 27, 2008 I have a PRC2734 ignition switch to fit a 110 ex-Army, the switch is numbered 1 to 5, does anyone know what colour wire goes to which terminal on the switch ??? Thanks http://www.lucaselectrical.co.uk/technical/SwitchgearTI.pdf might help & http://forums.lr4x4.com/index.php?showtopi...+starter+switch refer to the lucas extract switch number 35288 terminal numbers are 1 = 12v feed 2 = FSO [fuel shut-off ] 3 = Starter 4 = auxilary 5 = heater plugs don't know how I screwed up my original reply, somehow it got edited into your original question Quote Link to comment Share on other sites More sharing options...
Ex Member Posted November 14, 2018 Share Posted November 14, 2018 I suppose nobody saved the Lucas document? It is no longer online. Quote Link to comment Share on other sites More sharing options...
