western Posted October 27, 2008 Share Posted October 27, 2008 (edited) I've recently had to sort my heater sldes as all I got was very lukewarm air & next to no flow the left [fan] slide -- push it fully up to the 'O' position [off] on the inner face of the heater box, check that the spring clip for the cables outer sleeve is in place & the lever the wire inner cable is attached to fully up as far as it will go. if not, slacken the small cable grip bolt & push the lever fully up & tighten the cable grip bolt. on the right side the outer lever operates the flaps inside the heater duct [bottom of dash] with this outer lever fully up to the windscreen logo, the duct flaps should be closed on to the footwell air exits [remove the plastic ducts to check] the inner lever [hot/cold] operates the flap lever on top of the heater box, check this lever can move across it's full range, if not slacken the cable grip bolt/push the hot/cold lever fully up & note which way the inner cable moves, if it moves out [extends] move the heater box top lever the same way & tighten the cable grip & obviously vice versa. my heater lost one of it's cable outer clips so I had to check & reset both cables to get lots of lovely hot air into the cab hope it helps keep you toasty warm, mine does now. Edited September 28, 2011 by western 1 Quote Link to comment Share on other sites More sharing options...
callum Posted October 27, 2008 Share Posted October 27, 2008 its a question that comes up really often, might be worth sticking this post in the tech archive so folk can be pointed in its direction Quote Link to comment Share on other sites More sharing options...
western Posted October 27, 2008 Author Share Posted October 27, 2008 request for entry to tech archive done Quote Link to comment Share on other sites More sharing options...
roybatty666 Posted October 27, 2008 Share Posted October 27, 2008 Ta muchly I will have a look at mine as it blows like an asthmatic pensioner at the moment I have to put the fan to max and then push and wiggle it a bit more than that past where it should stop to get a wisp of heat Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted October 27, 2008 Share Posted October 27, 2008 I've done the same to mine, much better now Shame it doesn't help the fact that it takes 15 mins for the coolant to warm up enough Quote Link to comment Share on other sites More sharing options...
Guppy Posted October 27, 2008 Share Posted October 27, 2008 My heater works fine, but when set to blow onto the windscreen I get a torrent of hot air though the passenger-side vent but almost nothing through the driver's? Would that a cable issue or do I have a birds nest in a duct somewhere? Quote Link to comment Share on other sites More sharing options...
Projectblue Posted October 28, 2008 Share Posted October 28, 2008 I've recently had to sort my heater sldes as all I got was very lukewarm air & next to no flowthe left [fan] slide -- push it fully up to the 'O' position [off] on the inner face of the heater box, check that the spring clip for the cables outer sleeve is in place & the lever the wire inner cable is attached to fully up as far as it will go. if not, slacken the small cable grip bolt & push the lever fully up & tighten the cable grip bolt. on the right side the outer lever operates the flaps inside the heater duct [bottom of dash] with this outer lever fully up to the windscreen logo, the duct flaps should be closed on to the footwell air exits [remove the plastic ducts to check] the inner lever [hot/cold] operates the flap lever on top of the heater box, check this lever can move across it's full range, if not slacken the cable grip bolt/push the hot/cold lever fully up & note which way the inner cable moves, if it moves out [extends] move the heater box top lever the same way & tighten the cable grip & obviously vice versa. my heater lost one of it's cable outer clips so I had to check & reset both cables to get lots of lovely hot air into the cab hope it helps keep you toasty warm, mine does now. Nice one Ralph, I was blummin freezing coming home and couldn't figure out why there was no heat flowing - good timing cheers Quote Link to comment Share on other sites More sharing options...
dantd5 Posted October 28, 2008 Share Posted October 28, 2008 I guess I am lucky. My vent nearly cooks me up after 10 minutes. Happy winter season!! Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted October 28, 2008 Share Posted October 28, 2008 I had to change the blower motor on my Disco recently and was dismayed to find that - on what appeared to be an undisturbed installation - the heater control cables were so badly adjusted that at full extent of the lever movement the hot-cold flap was only 2/3 over so that the unit never blew fully hot! Legendary build quality eh? Now I can burn my fingers on the output vents [homer] mmm Toasty! [/homer] Quote Link to comment Share on other sites More sharing options...
Lars L Posted October 28, 2008 Share Posted October 28, 2008 Guppy, There are two alternatives depending on what you mean by "almost nothing". If it is nothing, the hose to the defroster might have fallen off at one end. It's instruments out to get to it... Then there is the Land Rover standard with the heater nearest to the passenger which also means that the nearest defroster gets more of the hot air. I have put a restriction in the hose on the pass side in form of the bottom of a tea candle with a maybe 10 mm hole in it. This way, the defroster air is more evenly distributed to both sides. Quote Link to comment Share on other sites More sharing options...
Guppy Posted October 28, 2008 Share Posted October 28, 2008 Thanks Lars, out with the screwdrivers at the weekend then! Quote Link to comment Share on other sites More sharing options...
Quagmire Posted October 28, 2008 Share Posted October 28, 2008 Best thing i did to improve the heater was fit a v8- some might think this a bit drastic though! Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted October 28, 2008 Share Posted October 28, 2008 I suppose this could be a cue for me to to come in and say just how quickly my Puma Defender warms up, just how much hot air the heating system produces in comparison to the earlier models I've owned, how nice it is to be able to direct that all that plentiful hot air pretty much where you want it including demisting the side windows... ...but I won't Shall we call a truce Ralph? Quote Link to comment Share on other sites More sharing options...
Anderzander Posted October 28, 2008 Share Posted October 28, 2008 Newbie question on this: Mine blows good warm air when the temp gauge eventually moves up a bit ... but the middle position on the settings doesn't seem to make much difference? at the top all the flow is from the top vents in the middle almost all of the flow is still at the top vents at the bottom its almost even from both vents I guess I expected the middle to be even - with the bottom position favouring the bottom vent. Is this about normal or are we up for some adjusting? Quote Link to comment Share on other sites More sharing options...
reb78 Posted October 28, 2008 Share Posted October 28, 2008 What are the opinions on the uprated heater matrixes. Mine has a hole and is currently not connected. Is it worth buying an uprated one or just making sure a new standard item works as efficiently as it can? (Its a 200tdi in a 110 so won;t get quite as warm as quickly as a V8 unfortunately!) Quote Link to comment Share on other sites More sharing options...
GL88 Posted October 28, 2008 Share Posted October 28, 2008 Newbie question on this:Mine blows good warm air when the temp gauge eventually moves up a bit ... but the middle position on the settings doesn't seem to make much difference? at the top all the flow is from the top vents in the middle almost all of the flow is still at the top vents at the bottom its almost even from both vents I guess I expected the middle to be even - with the bottom position favouring the bottom vent. Is this about normal or are we up for some adjusting? I have this too and am waiting for time and a dry day to investigate so would welcome pointers where to start. I know the flaps that control air into the footwells aren't opening so this could mean adjustment of the cable but do I do this at the lever or is it deeper in the bowels of the dash? And could it be caused by something else? Quote Link to comment Share on other sites More sharing options...
Exmoor Beast Posted October 28, 2008 Share Posted October 28, 2008 Oh FFS!!! Went to have a look at mine. Obviously its been a while since I moved the levers because they needed a bit of force you can see where this going can't you? Yep, snap! now the levers are just flopping about and I have to take the dash to bits to see whats broken Will Quote Link to comment Share on other sites More sharing options...
mickeyw Posted October 28, 2008 Share Posted October 28, 2008 Two Landrover heaters- One RRC 3.9 blows lovely warm air through in just a couple of minutes. One LR90 also with 3.9 V8 takes f ages before warm air comes through. I have already checked all the cables and flaps are correctly adjusted. It does blow nice'n'hot, eventually. But why such a difference in time 'till hot? They both use tons of fuel so ought to warm up quickly enough. Is it just down to the RRC having a bigger heater matrix? or is it that it takes a while longer to warm up the lower tinwork of a Landrover dash? What other tricks may there be in the RRC? I'm sure I read about someone piggybacking two heater matrices once into an oversized casing. That may have been with a series setup. Has anyone tried this with a Defender type, and still got it to line up with the intake duct in the wing? Quote Link to comment Share on other sites More sharing options...
Lars L Posted October 28, 2008 Share Posted October 28, 2008 I think the difference is that while the RRC only needs to heat up the hoses, almost the whole dash of the 90 needs to be warm before anything can escape where it should. Quote Link to comment Share on other sites More sharing options...
vinny Posted October 28, 2008 Share Posted October 28, 2008 this looks promising but might be waiting a while for production http://www.trucktrend.com/features/news/20...ator/index.html Was thinking along the lines of a compressor 12v clutch and a water pump?? Quote Link to comment Share on other sites More sharing options...
Anderzander Posted October 28, 2008 Share Posted October 28, 2008 Only draw back with that is that its just more drag on the motor I guess? Anyone confirm the correct heater lever function on a defender? as per mine and GL88's post above? Quote Link to comment Share on other sites More sharing options...
western Posted October 28, 2008 Author Share Posted October 28, 2008 I suppose this could be a cue for me to to come in and say just how quickly my Puma Defender warms up, just how much hot air the heating system produces in comparison to the earlier models I've owned, how nice it is to be able to direct that all that plentiful hot air pretty much where you want it including demisting the side windows......but I won't Shall we call a truce Ralph? Hello buddy nice timing good to know you won't freeze. Quote Link to comment Share on other sites More sharing options...
western Posted October 28, 2008 Author Share Posted October 28, 2008 Only draw back with that is that its just more drag on the motor I guess?Anyone confirm the correct heater lever function on a defender? as per mine and GL88's post above? in my info above I've detailed which lever moves which vent flaps. Quote Link to comment Share on other sites More sharing options...
GL88 Posted November 1, 2008 Share Posted November 1, 2008 I know the flaps that control air into the footwells aren't opening so this could mean adjustment of the cable but do I do this at the lever or is it deeper in the bowels of the dash? Answering my own question, I've just taken the hot/cold and up/down levers off mine and the reason the footwell flaps weren't opening is because the clamp on the cable wasn't tight. This meant that moving the distribution lever just pulled and pushed the outer cable together with the inner - one minute with an 8mm spanner and all is fine. I took the opportunity to wave the 3in1 oil around too and now everything is smooth too. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted November 1, 2008 Share Posted November 1, 2008 in my info above I've detailed which lever moves which vent flaps. I've been meaning to come back to this. What I was after was not what lever did what or where to adjust it.... though I realise if I figure out how to adjust the cable for the vent it all it should become right ....... but does the vent lever work on all Landy's like it does on mine (before I go and try and adjust it)..... ie - top position - windscreen vent - middle position - still windscreen vent - bottom position - windscreen and bottom vent As Western described on the right side the outer lever operates the flaps inside the heater duct [bottom of dash] with this outer lever fully up to the windscreen logo, the duct flaps should be closed on to the footwell air exits [remove the plastic ducts to check] well mine seems to be fully closed in the middle position .... is that normal? or should it be half open? Quote Link to comment Share on other sites More sharing options...
