Daan Posted January 25, 2006 Share Posted January 25, 2006 whoah!!!! Let's go back and look at the question:The first is objective, the one that I responded to, not having seen the second one, which is purely subjective. ... but ofcourse if you want to discuss the merits of both types of fan even to restart the electric vs viscous debate then continue.... B) Lets blow my trumpet again because I think i found the best: SUCK and BLOW! Cant go wrong there at any speed, especially because it can be Electric AND Viscous! Daan Quote Link to comment Share on other sites More sharing options...
jules Posted January 25, 2006 Share Posted January 25, 2006 Cant go wrong there at any speed, especially because it can be Electric AND Viscous!Daan That what I run I can't help but think the engine bay of the cars I own with fans are freelanders suck Ford Focus suck Pug 205 1.6 & 1.6 Blow days of old 21 turbo suck Quadra turbo Suck 306 pug suck 106 pug suck 1.6 Mk 5 escort suck The majority suck some in more ways than others Quote Link to comment Share on other sites More sharing options...
simonr Posted January 25, 2006 Share Posted January 25, 2006 Can yer tell what it is yet??? Apart from a rather wonky fag-packet drawing. 1st itteration of the design, but I'm working on it! Si Quote Link to comment Share on other sites More sharing options...
Diff Posted January 25, 2006 Share Posted January 25, 2006 Can yer tell what it is yet??? Apart from a rather wonky fag-packet drawing. 1st itteration of the design, but I'm working on it! Si Mechanical fan hub with an electrically operated clutch? Like an aircon pump clutch so it can be locked/unlocked by switch or operated automatically by a thermostat? If it isn't, it should be, as that would be the best of both worlds. Regards, Diff Quote Link to comment Share on other sites More sharing options...
mmgemini Posted January 25, 2006 Share Posted January 25, 2006 I'll volunteer to test that Simonr. I eat rat poison mike I can cause trouble in an empty house. Quote Link to comment Share on other sites More sharing options...
Mark90 Posted January 25, 2006 Share Posted January 25, 2006 1.6 Mk 5 escort suckThe majority suck some in more ways than others Aye Mk 5 escorts suck, in fact all but mk 1's and 2's suck. Quote Link to comment Share on other sites More sharing options...
simonr Posted January 25, 2006 Share Posted January 25, 2006 Mechanical fan hub with an electrically operated clutch? Like an aircon pump clutch so it can be locked/unlocked by switch or operated automatically by a thermostat?If it isn't, it should be, as that would be the best of both worlds. Regards, Diff Could Be! It struck me as the best of both worlds too! It was drawn in the pub about the size oof a postage stamp on the back of a beer mat! Doesn't look so good blown up. I'll see if I can find some fans and knackered viscose units for the thread sizes and hole centres - and build a prototype using the coil from an air-con pump. Si Quote Link to comment Share on other sites More sharing options...
white90 Posted January 25, 2006 Share Posted January 25, 2006 Si I have a 300TDI viscous fan unit with a worn bearing somewhere you can have I'll bring it to slindon if you want Quote Link to comment Share on other sites More sharing options...
Daan Posted January 26, 2006 Share Posted January 26, 2006 It was drawn in the pub Are you mad? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 26, 2006 Author Share Posted January 26, 2006 Hydraulic, now there's a plan! Quote Link to comment Share on other sites More sharing options...
Daan Posted January 26, 2006 Share Posted January 26, 2006 Hydraulic, now there's a plan! I ve seen it done, using the powersteering system. The winner of the last RFC was running this to operate his rear mounted radiator. It was using standard Toyota components. Daan Quote Link to comment Share on other sites More sharing options...
simonr Posted January 26, 2006 Share Posted January 26, 2006 SiI have a 300TDI viscous fan unit with a worn bearing somewhere you can have I'll bring it to slindon if you want Cheers Tony, That would be fab! Si Quote Link to comment Share on other sites More sharing options...
