stevie1690 Posted October 29, 2008 Share Posted October 29, 2008 HI landy lovers im wanting to fit a 300 tdi into my classic rangerover which had a v8i auto can i use the auto box or will another auto box fit at the moment the 300 has a 5 speed manual and also does a 200 turbo fit a 300 turbo cheers stevie Quote Link to comment Share on other sites More sharing options...
bishbosh Posted October 29, 2008 Share Posted October 29, 2008 You can fit a 300 to a V8 autobox but it is not straightforward - drop Turbocharger a PM as he has done this in a 90. You would be better off buying a 300tdi auto disco and swapping bits across. Quote Link to comment Share on other sites More sharing options...
landybehr Posted October 29, 2008 Share Posted October 29, 2008 see http://www.mdengineering.co.uk/index.php?a...ry&cat_id=2 and there kit 82a whicht should be what you need. bishbosh is right I think. Just 2 points to add a) 300tdi auto boxes are harder to find than for the V8. B) the TDI-auto box (torque converter) cannot handle much more torque than the 300tdi delivers. It will work, apparantly, as you might expect from a factory setup, but I´ve heard of problems with the 4.gear lock-up with tuned TDI´s. The V8 autobox is better in dealing with stronger engines. OTOH the V8 shifing points are completely wrong for the TDI. That could be put right with some few parts (speed governer and kickstart excenter - things Ashcroft will be able to help with). So, in the end, you should listen to Bishbosh Quote Link to comment Share on other sites More sharing options...
stevie1690 Posted October 30, 2008 Author Share Posted October 30, 2008 You can fit a 300 to a V8 autobox but it is not straightforward - drop Turbocharger a PM as he has done this in a 90.You would be better off buying a 300tdi auto disco and swapping bits across. thanks a lot for your help again lads a think i'll stay with the manual box just now cheers stevie Quote Link to comment Share on other sites More sharing options...
