Mo Murphy Posted January 26, 2006 Share Posted January 26, 2006 Oil coats the metal around the bell housing drain hole. This is going to be an effing engine out job isn't it ? Mo Quote Link to comment Share on other sites More sharing options...
Dale Simpkins Posted January 26, 2006 Share Posted January 26, 2006 Oil coats the metal around the bell housing drain hole. This is going to be an effing engine out job isn't it ? Mo Sounds like it. Got to be either engine crankshaft oil seal, or gearbox oil seal. Unless it's a cracked engine block, or gearbox case! Then you'd be really angry I had a cracked gearbox casing once, on one of my previous motors. That was very annoying! Quote Link to comment Share on other sites More sharing options...
western Posted January 26, 2006 Share Posted January 26, 2006 Oil coats the metal around the bell housing drain hole. This is going to be an effing engine out job isn't it ? Mo Could be from the sump to block joint & the oil is blowing backwards while driving, just a thought Quote Link to comment Share on other sites More sharing options...
white90 Posted January 26, 2006 Share Posted January 26, 2006 firstly check it is oil my slave cylinder failed and leaked into the bellhousing then x2 rear crank seals under warranty oil leak appears again nothing bad just a small amount, if I leave the wading plug in for ages no oil of any note appears when the plug is removed. unless it is pouring out I would just ignore it. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 27, 2006 Author Share Posted January 27, 2006 Ah, the voices of reason I shall investigate further. Mo Quote Link to comment Share on other sites More sharing options...
