jamesmyl110 Posted November 10, 2008 Share Posted November 10, 2008 Has anyone got a definitive answer on the temp sender issue for disco motors in defenders? got a disco motor in my '86 110 which used to be 2.5NA with a steve parker sender and it still reads hgh, when the motor was in the disco it always ran pretty cool. Can anyone reccomend a sender that works at the correct temp range as the 110 setup reads the temp in the head not at the thermostat housing. Or maybe a guage that will work at the right range?? Cheers all Quote Link to comment Share on other sites More sharing options...
Lars L Posted November 10, 2008 Share Posted November 10, 2008 A VDO gauge and a VDO sender does it for me. Quote Link to comment Share on other sites More sharing options...
western Posted November 11, 2008 Share Posted November 11, 2008 Correct Defender 200Tdi temp sender that screws in the thermostat housing is PRC8593, that should work with your existing gauge. Quote Link to comment Share on other sites More sharing options...
MattYorke Posted November 17, 2008 Share Posted November 17, 2008 Do you know what thread PRC8593 is? Many thanks Matt Correct Defender 200Tdi temp sender that screws in the thermostat housing is PRC8593, that should work with your existing gauge. Quote Link to comment Share on other sites More sharing options...
western Posted November 23, 2008 Share Posted November 23, 2008 I'm not sure of the thread type, but I believe it has been mentioned on here previously by guys doing the same engine swap. Quote Link to comment Share on other sites More sharing options...
