V8 EFi Wiring
Mike Brownlie
Hi guys,
im helping another member with a 3.9efi conversion and im looking for some assistance with the wiring.
the engine and all ancilarys work as we removed them from a running 1989 rangerover.
so far i have managed to get the engine turning over and main relays click.
checked for spark from a spark plug but none.
so,
1. can anyone advise me on what the connections and wire colours are on the white plug on the rangerover connector ?
2. has anyone got the pin outs on the 200tdi engine plug (rectangle one)
3. does the fuel system need to be presurised to get a spark ?
4. the coil +12v can be taken from the aux on the altenator ??
5. the interference suppressor is it important ?
any other hints tips appreciated.
oh, im not going carb or megasquirt on this one !
cheers
mike
Mike,
CAn you post up the RR V8 wire colours you have, I can sort of almost rememebr but can't think what all the colours are, some are joined together in the plug mention those to
If I can't remember BBC or Mr Fridge will know
From memory and I may be getting me flapper and me Hotwire mixed up
White purple fuel pump - 12v feed ignition on
Thick Brown or thicj white and something - main power feed
White = 12v ignition on
White and red thin = cranking ?
and then me mind goes all blank like :lol:
Rather than to risk my memory hopefully someone will cross check agree the above, rather than let the famous lucas harness smoke escape
Nige
PS MS It :P:lol:
I believe the wiring for the hotwire efi is in the tech info section which will save me trying to read out 40 wire colours.
I believe the ignition will be shown on the main wiring but coil negative goes via a resistor into pin 39 on the ecu
The +12v should be ignition switched live (white) and go to both the coil +ve and the ignition amp and the capacitor.
ignition amp (white/black) goes to -ve on coil.
steve
ETA everyone else jumped in while I was looking in the book. Would add though that the wiring changes again from 1990.
  • 2 months later...
Thanks for the replies guys. Its me he's helping.
I have that very same diagram, but i was wondering. Is it the same as mine because mine dont have Lambda sensors?
Also having trouble getting a spark at the moment. Iv mucked around with the coil wiirng and i think iv got it right. What else should i look at?
You need sparks before the ECU will even think about firing the injectors, so you need to sort that first and check the feed (white/black) from coil -ve to the ECU is connected.
If you don't have lambda sensors, just ignore them on the diagram, everything else should be the same.
