Warthog Posted January 30, 2006 Share Posted January 30, 2006 Brought a secondhand Come Dv9000 awhile ago and have just got around to fitting it. But the Free spool function is pretty hard to use? It needs a fair amount of oomph! to get it spooling? Ran the winch a few time with load and without and it seems to run O.K......But the freespool is still hard. What possible issues could affect this? Any ideas would be greatly appreciated PG winches "Guru" will be my next port of call. Quote Link to comment Share on other sites More sharing options...
pritch1 Posted January 30, 2006 Share Posted January 30, 2006 Having same problem with mine at the moment, it has gone before but managed to free it just by pulling it on and off. It now seems to have seized all together, really dont want to strip the whole thing apart. If i rember correctly lots of spray greece worked before, not sure if its the right thing to do though Quote Link to comment Share on other sites More sharing options...
Warthog Posted January 30, 2006 Author Share Posted January 30, 2006 Having, stripped the it down. Not a complete strip, but just to check the planetary gears etc. Found that upon re-assembly, the freespool was a little better. But i didnt dis-assemble the brake unit. I am wandering if the brake/clutch has stuck on slighty??? Quote Link to comment Share on other sites More sharing options...
will_warne Posted January 31, 2006 Share Posted January 31, 2006 Brake is possibly sticky. I know Les Brocklehurst had simerlar problems when he abused his too much. Very few of the in drum winch brakes seem to take kindly to hard use. New parts are pretty easily available, though. Quote Link to comment Share on other sites More sharing options...
