Tractorboy16 Posted November 25, 2008 Share Posted November 25, 2008 Hi, quick question, had a look on technical section and couldn't find it, How much oil should be put in an 8274? and is gear oil ok? many thanks James Quote Link to comment Share on other sites More sharing options...
western Posted November 25, 2008 Share Posted November 25, 2008 MAINTENANCE • No lubrication is required for the life of the winch, unless the winch is submerged in water. If this occurs, a qualified service center must complete service as soon as possible to prevent corrosion damage. . found the above staement in this document 8274-50 owners handbook on page 8. http://www.warn.com/truck/winches/src/images/59/38292D3.pdf in the spec list it states Lubrication: 6 oz. SAE 30 (non-detergent) on this page http://www.warn.com/truck/winches/src/M8274-50.shtml Quote Link to comment Share on other sites More sharing options...
Boothy Posted November 25, 2008 Share Posted November 25, 2008 I use half a litre of EP90, does fine, been told you could use a thick'ish engine oil something like 20/50 if you choose. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 25, 2008 Share Posted November 25, 2008 I use EP90 too. Mo Quote Link to comment Share on other sites More sharing options...
ciderman Posted November 25, 2008 Share Posted November 25, 2008 I use 75/90 semi synthetic gear oil , we use it at work in trencher gearboxes and they get a right hammering , I just fill it so the level is halfway up the drum gear . Quote Link to comment Share on other sites More sharing options...
Dutchgit Posted November 26, 2008 Share Posted November 26, 2008 Gear oil. Don't know what type exactly as it's been a while but when getting parts for my 8274 the chaps who imported them here told me to use no more that a tea cup full. Quote Link to comment Share on other sites More sharing options...
samwilk200 Posted November 26, 2008 Share Posted November 26, 2008 I used 0.2 litres of gear oil. Quote Link to comment Share on other sites More sharing options...
Dave W Posted November 26, 2008 Share Posted November 26, 2008 I use SAE30 engine oil as that's what I use in my engine so I always have some available I've also used ATF in the past. Too thick an oil won't move around enough as it relies on splash lubrication for the upper gears and bearings, the SAE30 gets everywhere. You only need enough to fill the winch to the bottom of the drum. Any more than that and it will probably leak out anyway. Quote Link to comment Share on other sites More sharing options...
will_warne Posted November 26, 2008 Share Posted November 26, 2008 I used SAE30 bought from my local agricultural supplier (this is very cheap) and changed regularly - regular changes are vital as these winches aren't well sealed. As a result using expensive oil gets very expensive. Given how often you do changes get hold of an old jam jar and mark it up for the volume. Quote Link to comment Share on other sites More sharing options...
robhybrid Posted November 26, 2008 Share Posted November 26, 2008 the correct level is 200ml 0.2litre when you put it in it dosent lok like a lot but it is well splashed arround by the big gear. more oil puts extra drag on the gears, and will leak out if the main drum seal isnt absolutely perfect. the best possible oil is fully synthetic ep90 you wont belive the difference it makes to the speed I have to take the top cover off both of mine and change the oil in them after every howling wolf event Quote Link to comment Share on other sites More sharing options...
mickeyw Posted November 27, 2008 Share Posted November 27, 2008 I used 0.2 litres of gear oil. Same here Quote Link to comment Share on other sites More sharing options...
Eddie Posted December 10, 2008 Share Posted December 10, 2008 I have been told to use 0.25L of ATF! Quote Link to comment Share on other sites More sharing options...
