pugwash Posted November 26, 2008 Share Posted November 26, 2008 Well i might not get everything i want, but i'm looking for a compressor suitable for expedition use (ie reliable) that can air tyres up and down reasonably quickly and if possible power air tools without an enormous tank: Priorities: Reliability Performance Size (doesn't need to be tiny but it can be huge either) Noise In that order Things that don't matter: Amp Draw Heat Portability (it will be hard mounted) dust Protection (will be mounted in semi enclosed compartment) what works and what doesn't? Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted November 26, 2008 Share Posted November 26, 2008 Puggers Everyone seems to rave about the twin cyl T-Max compressor. Not sure if James has one or he borrowed it. Bearmach do them quite cheaply IIRC. Are you about for a call in a bit Quote Link to comment Share on other sites More sharing options...
white90 Posted November 26, 2008 Share Posted November 26, 2008 James had my one a while back superb piece of kit will reseat a tyre easily and pumps up x4 tyres in no time £65-75ish from Foundry 4x4 on ebay when I ordered a couple, after using Honiton hobbits one at an event http://cgi.ebay.co.uk/T-Max-Heavy-Duty-Twi...%3A1|240%3A1318 If you want to power tools then Matt savage sells the range SteveG has far more spendy/ better quality(build wise) the clips on the T max are rubbish. Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted November 26, 2008 Share Posted November 26, 2008 That's the 1. Wasn't sure who owned it. Quote Link to comment Share on other sites More sharing options...
TJ101 Posted November 26, 2008 Share Posted November 26, 2008 That's the 1. Wasn't sure who owned it. You spend last weekend, 2 foot away from one !!! Yep, the T-max twin, is the one i have as well,, perfect for the jobs Tony lists,,,but would not say man enough for running power tools etc Better for you, i would have though is to think about a system off the A/C pump Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted November 26, 2008 Share Posted November 26, 2008 Better for you, i would have though is to think about a system off the A/C pump Really the only option, IMHO, if you are serious about using air tools, especially without a large tank. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 26, 2008 Share Posted November 26, 2008 I doubt anything 12 volt would provide enough oomph for air tools without a decent sized tank as a buffer. My 2HP 25L compressor won't keep up with a rattle gun, 2HP is about 1.5KW which if was 12 volts would be sucking about 125 amps so it doesn't take long to figure out that the maths don't add up in providing sufficient power from a 12 volt battery for anything other than short bursts. I have also been thinking about the Tmax one as it seems a reasonable compromise of cost vs performance and much better than the one I have at the moment which mostly seems to convert 12 volts into noise and vibration (keep it clean...) however I wasn't going to run air tools off it. I did order it at one stage but it was on back order and missed the shipment we had coming in. I suppose if you could pick up a reciever from a dud 25L compressor and stuff it out of the way somewhere you might get a passable system that could be used for odd jobs. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 26, 2008 Share Posted November 26, 2008 Discussed here previously http://forums.lr4x4.com/index.php?showtopic=17405 http://forums.lr4x4.com/index.php?showtopic=20613 Quote Link to comment Share on other sites More sharing options...
Paul Humphreys Posted November 26, 2008 Share Posted November 26, 2008 If its for the LC, there are pictures of a York pump fitted to a 4.2 on Ih8mud. The tank could be fitted under the rear floor where the spare wheel is. Paul Quote Link to comment Share on other sites More sharing options...
pugwash Posted November 26, 2008 Author Share Posted November 26, 2008 dont want to lose the A/C if i can help it as i am hoping to travel to warmer climes at some point- and it would be nice to have an ice cold car (and i bought a brand new AC condenser not so long ago for quite a lot of pennies). Engine bay not big enough to fit in two compressors- although if you find that link of a york pump on a 1HD-T on ih8mud then i'd be interested in seeing it Paul. Tony what has your experience of the double header T-max jobby been? realiable? noisey? etc etc Quote Link to comment Share on other sites More sharing options...
Paul Humphreys Posted November 26, 2008 Share Posted November 26, 2008 Some more pics will be posted in this thread http://forum.ih8mud.com/diesel-tech-24-vol...rd-battery.html Paul Quote Link to comment Share on other sites More sharing options...
white90 Posted November 26, 2008 Share Posted November 26, 2008 Jim It is fine really blown up air beds/swimming pools reseated Simex on modulars blown up tyres on beadlocks reseated BFGs okish as a air gun to blow out small things, James inflated a flat tractor tyre with it. Can't flt it at all bar the crappy croc clips and PCL fitting (cheapo) but easily rectified (even though I haven't bothered to my shame Quote Link to comment Share on other sites More sharing options...
Mark Posted November 26, 2008 Share Posted November 26, 2008 As has been said, running air tools is going to require a decent tank or much bigger compressor. I have one of the t-max compressors installed in the disco and have been very pleased with it... Mark Quote Link to comment Share on other sites More sharing options...
simonr Posted November 26, 2008 Share Posted November 26, 2008 Have you considered a foot pump? If you install JST with it - I'm sure it will run air tools quite happily! Si Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted November 27, 2008 Share Posted November 27, 2008 Have you considered a foot pump? If you install JST with it - I'm sure it will run air tools quite happily! Si He's got nowt else todo for the next 15 yrs or so. Quote Link to comment Share on other sites More sharing options...
JST Posted November 27, 2008 Share Posted November 27, 2008 James inflated a flat tractor tyre with it. it inflated a completely flat rear tractor tyre in the time it took me to throw the ball for the dog and her bring it back 6 times - so about 3mins i reckon - very impressed with it. Have you considered a foot pump? If you install JST with it - I'm sure it will run air tools quite happily! and sit in puggers garage going nowhere for years - i can do that in my own truck :ph34r: Quote Link to comment Share on other sites More sharing options...
dollythelw Posted November 28, 2008 Share Posted November 28, 2008 We've found those T max twin jobbies even work after a good dunking - just give'em a second to clear the water out of the line and away they go, the switch box is pants and needs replacing with somehing more robust beforehand though, great bit of kit for the money Quote Link to comment Share on other sites More sharing options...
