v8bertha Posted December 4, 2008 Share Posted December 4, 2008 Morning all, Jumped in the freelander this morning (2ltr L series diesel) to go to work. Engine started and idled fine. But then as I started to drive up the hill it lost all power. It still idled fine and would rev up ok. But tried to pull away again and it wouldn't rev at all unless I dipped the clutch Ain't gonna be able to have a look at it until next week now, but anybody got any pointers about where to start looking? Cheers Dan Quote Link to comment Share on other sites More sharing options...
v8bertha Posted December 4, 2008 Author Share Posted December 4, 2008 Ok... just got home and had a little test. The symptoms in more detail are: Start engine fine, idle fine, revs fine. Clutch in, engage gear, still revs fine. Let clutch out without giving the engine any more revs, and then try to accelerate it just stays at idle. If I dip the clutch and blip the throttle, it revs up, re-engage the clutch it will then pull fine as if nothing is wrong. Once up to speed and changing through the gears the same is true, if the engine is at idle speed when the clutch is engaged, it won't accelerate. Wierd! Now, something else I've noticed aswell now that its dark... all the brake lights are on if I put either the side lights or headlights on. However, they are not at full brightness, i.e. if I depress the brake pedal they get a smidgen brighter. With the lights off the brake lights work as you'd expect. Could this be related? Is the 2lt L series fly-by-wire that could be shorting something out or is there a good old-fashioned throttle cable in there somewhere? Thought... If the HDC were stuck on somehow, would that put the brake lights on? Any help greatly appreciated as I'm gonna have to run the 110 until its fixed.... mucho £££ Cheers all Dan Quote Link to comment Share on other sites More sharing options...
orangemach5 Posted December 4, 2008 Share Posted December 4, 2008 No throttle cable Wallace, all fantastic fly by wire! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 4, 2008 Share Posted December 4, 2008 1st point of call with strange electrical faults is dodgy earth, although beyond that you're on your own as I don't do diseasals Quote Link to comment Share on other sites More sharing options...
ChrisV8 Posted December 5, 2008 Share Posted December 5, 2008 Have a look at the diesel section on here lots of info, sounds like a wire broken in the engine harness which is quite common. http://forums.mg-rover.org/forumdisplay.php?f=104 Quote Link to comment Share on other sites More sharing options...
carpenter-dj Posted December 5, 2008 Share Posted December 5, 2008 Hi Dan, I had a simalar problem the other day with my freebe (2lt TD), it turned out to be the air in take valve to the turbo, it was full of water, had been installed backwards. hope you find the problem. Cheers Dave Quote Link to comment Share on other sites More sharing options...
v8bertha Posted December 5, 2008 Author Share Posted December 5, 2008 Chris, Thanks for the link, there is some useful info there, some of which has actully rang a few alarm bells! Cheers Dave, I'll add that to the list of checks to make. JU and Paul... thanks a lot chaps.... I hate wiring! Quote Link to comment Share on other sites More sharing options...
orangemach5 Posted December 6, 2008 Share Posted December 6, 2008 Dan, Ive got diagnostic's which go on the freebe, if you want i can pop around one evening after work to check all sensor values are active and check for faults etc etc, just let me know! Quote Link to comment Share on other sites More sharing options...
Blippie Posted December 8, 2008 Share Posted December 8, 2008 Have a look at the diesel section on here lots of info, sounds like a wire broken in the engine harness which is quite common.http://forums.mg-rover.org/forumdisplay.php?f=104 www.tuning-diesels.co.uk is handy too! Try: http://tuning-diesels.com/Lseries/faults2.htm or http://tuning-diesels.com/Tuneam/tuneam.htm PS, I don't like the colour of yours, Dan. Cheers Blippie Quote Link to comment Share on other sites More sharing options...
v8bertha Posted December 10, 2008 Author Share Posted December 10, 2008 Ok... thanks to Young Paul (orangemach5) and his buddy Damian, my freelander is working again The cause of the problem is almost embarrasing to admit, but lets see if you can see it What is wrong with the bulb in the picture? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 10, 2008 Share Posted December 10, 2008 Next time get Jen to take the photo At a guess it's failed short circuit somehow, difficult to see from the piccy though. Quote Link to comment Share on other sites More sharing options...
v8bertha Posted December 11, 2008 Author Share Posted December 11, 2008 Cheeky sod... ain't nowt wrong with my photo-graphing ya know Anyway, you are right, there is a short between the 2 filaments meaning that when I put the side lights on, the brake lights also came on. This in turn tells the ECU that you can't accelerate because your foot is on the brake. Clever stuff init... But I think I prefer uncomplicated stuff like Defenders!! D :-) Quote Link to comment Share on other sites More sharing options...
T1G UP Posted December 11, 2008 Share Posted December 11, 2008 who thought of that one! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 11, 2008 Share Posted December 11, 2008 Easily fixed with the application of wire cutters & heatshrink Quote Link to comment Share on other sites More sharing options...
Blippie Posted January 4, 2009 Share Posted January 4, 2009 FFS, a 25 pence bulb causing all that trouble ... Cheers Blippie Quote Link to comment Share on other sites More sharing options...
v8bertha Posted January 5, 2009 Author Share Posted January 5, 2009 FFS, a 25 pence bulb causing all that trouble ...Cheers Blippie Yup When I get the baby-poo coloured one on the road, I'm gonna test it by putting the bulb in that one, see if I get the same problem (if I can keep it safe that long!!) D Quote Link to comment Share on other sites More sharing options...
Blippie Posted January 6, 2009 Share Posted January 6, 2009 Our LBPB is tucked up nice and warm in our new garage for the winter. Mother in law is making a nice cosy cover for it out of the old red velvet curtains that were in our house when we moved in. Barking! Can't wait to see your LBPB on the road. I think ours could tell each other some stories. Cheers Blip Quote Link to comment Share on other sites More sharing options...
