big ives Posted December 5, 2008 Share Posted December 5, 2008 i am rebuilding a 300tdi 90 and i am at the stage of putting the engine and box back into the landy, i have read that fitting a disco transfer box gives better performance how true is this? are there any down sides? i have a good transfer box from a 200tdi disco, will it work with the gearbox from the 300tdi defender??? have done a search just want to ask somebody who has done this to a 300tdi many thanks Quote Link to comment Share on other sites More sharing options...
jason110 Posted December 5, 2008 Share Posted December 5, 2008 all i can say is that i have fitted a disco t'box to my '86 110, which has a disco 200tdi, and difference is quite incredible, as for fitting it to a later g'box im sure someone who knows the answer will be along shortly to give u a definitive answer! but u can always give it a go! Quote Link to comment Share on other sites More sharing options...
big ives Posted December 5, 2008 Author Share Posted December 5, 2008 thanks jason will wait and see if some one can enlighten me with engine and box out and split would hate to miss the chance to make the ole girl go faster Quote Link to comment Share on other sites More sharing options...
western Posted December 5, 2008 Share Posted December 5, 2008 LT230 transfer boxes will fit the LT77 or R380 main gearboxes. Quote Link to comment Share on other sites More sharing options...
defender dave Posted December 5, 2008 Share Posted December 5, 2008 LT230 transfer boxes will fit the LT77 or R380 main gearboxes. hi I fitted one on my defender and the only downside for me is its a bit slow pulling away as i have large tyers but top end is much better Quote Link to comment Share on other sites More sharing options...
101sean Posted December 5, 2008 Share Posted December 5, 2008 General opinion is fitting a Disco Tbox is a good move unless you run heavily loaded or tow a lot. It will fit straight on, may have to mess with handbrake bracketry. Won't increase performance (accleration will be slower) but cruising will be more comfortable (you won't go faster, engine just won't be screaming it's nuts off). If you want to go faster, search the tuning threads after you've swapped boxes. If you want more advice on this, do a search, has to be one of the most common Defender questions. Quote Link to comment Share on other sites More sharing options...
Badger90 Posted December 5, 2008 Share Posted December 5, 2008 General opinion is fitting a Disco Tbox is a good move unless you run heavily loaded or tow a lot.It will fit straight on, may have to mess with handbrake bracketry. Won't increase performance (accleration will be slower) but cruising will be more comfortable (you won't go faster, engine just won't be screaming it's nuts off). If you want to go faster, search the tuning threads after you've swapped boxes. If you want more advice on this, do a search, has to be one of the most common Defender questions. i wil have to agree.. i have just fitted a discovery box into my defender. with tweeked fuel pump and uprated intercool it pullls off much quicker i must say. but i do regret it. yes towing is a bugger as so are head winds on motorway but it save little more on fuel. i was told when fitting mine to cut the end thread on the main shaft to makes it sooooo much easyer to put on.. it really did.. it not used for anythink... Quote Link to comment Share on other sites More sharing options...
big ives Posted December 6, 2008 Author Share Posted December 6, 2008 thanks to everyone for there advice ta Quote Link to comment Share on other sites More sharing options...
Shox Dr Posted December 6, 2008 Share Posted December 6, 2008 Before you spend your hard earned, you need to find out what the ratio of the box is, Disco's had 1:1410 fitted as well. If the ratio label is no longer there, you can look up the ratio on Ashcrofts site. http://www.ashcroft-transmissions.co.uk/part_8.html#pa1 I have a 1:122 fitted toa 300tdi with 265/70 16 and it's fine Quote Link to comment Share on other sites More sharing options...
Monster Posted December 6, 2008 Share Posted December 6, 2008 i am rebuilding a 300tdi 90 and i am at the stage of putting the engine and box back into the landy, i have read that fitting a disco transfer box gives better performance how true is this? are there any down sides?i have a good transfer box from a 200tdi disco, will it work with the gearbox from the 300tdi defender??? have done a search just want to ask somebody who has done this to a 300tdi many thanks Hi, Whereabouts are you located. Maybe interested in your old 1.4 box! Cheers. Quote Link to comment Share on other sites More sharing options...
