puiwit Posted December 16, 2008 Share Posted December 16, 2008 i would like to change my front doors of my defender td5. there are one-piece doors available, with series door handle, that is important! but that are not the typical series doors consisting of two-piece, top and bottom. i can not find them in part catalogs and manuals. please give me your advice with details about the type, part numbers, pictures and supplier. thank you! Quote Link to comment Share on other sites More sharing options...
Ivan Posted December 16, 2008 Share Posted December 16, 2008 Can't help with part numbers etc. But I do know they were fitted to the very first 90's. My mate has an A Reg 90 (1983?) and his has the one piece doors with lift up handles ala Series. They also have wind down windows. HTH Ivan Quote Link to comment Share on other sites More sharing options...
puiwit Posted January 5, 2009 Author Share Posted January 5, 2009 i have found some pictures about the required doors. any part numbers, supplier or other information available? thank you! Quote Link to comment Share on other sites More sharing options...
dirkthe1 Posted January 5, 2009 Share Posted January 5, 2009 could you not just have them as the 2 piece ones-i didnt even know they made 1 piece ones! or is the ability to wind down the window integral? Quote Link to comment Share on other sites More sharing options...
western Posted January 5, 2009 Share Posted January 5, 2009 those are the first style of wind down window doors, they should still be available. Craddocks have them listed Part Number : STC543 DOOR CLINCHED ASSY LH 90/110 LIFT UP HANDLE TYPE Part Number : STC542 DOOR CLINCHED ASSY RH 90/110 LIFT UP HANDLE TYPE others like Simmonites/Paddocks probably can supply too. Quote Link to comment Share on other sites More sharing options...
tychoS Posted January 5, 2009 Share Posted January 5, 2009 i have found some pictures about the required doors. The doors on those pictures match the doors on early 90" and 110" perfectly. Check that the recess for the external handle is not rusted out. They are designed to trap water, as are the steel frame at the bottom of the door. Quote Link to comment Share on other sites More sharing options...
western Posted January 5, 2009 Share Posted January 5, 2009 The doors on those pictures match the doors on early 90" and 110" perfectly Hmm wonder why that is, Ah I know cos they are early windy window doors from a earlier 90 or 110 Quote Link to comment Share on other sites More sharing options...
dave88sw Posted January 5, 2009 Share Posted January 5, 2009 can i ask why you want them? just wondering whether theres a special reason ive missed Quote Link to comment Share on other sites More sharing options...
puiwit Posted January 6, 2009 Author Share Posted January 6, 2009 @western big thanx for your help with the part numbers!!! @dave88sw i have a defender td5 with the door push button handles. unfortunately i have broken several doors at trees on challenge events. now i think this doors are a good solution. the standard series doors have disadvantages at the windows, even look out with helmet, aso... lets see, if they are available and how long they survive unscathed? Quote Link to comment Share on other sites More sharing options...
western Posted January 6, 2009 Share Posted January 6, 2009 happy to help, hope you can find a good pair of doors. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted January 6, 2009 Share Posted January 6, 2009 Another good reason for lift handle doors is the fact that the latches don't freeze up in the cold. We have had 3 later Defenders with push button doors that persistently freeze up. If it's not the lock barrel that freezes, the button will stick in when you press it to open the door. Regular application of WD40 helps to some extent, as does wrapping a towel round the door handle at night. Fortunately the latest 110 has remote locking, so at least that eliminates the key problem Quote Link to comment Share on other sites More sharing options...
