Smokydiesel Posted August 17, 2005 Share Posted August 17, 2005 Hi,A friend of mine is fitting power steering in his 90 2.5 NA at the moment.In order to hook up the belt-driven pump, he needs to fit a double pulley to the crankshaft, but he has a bit of trouble finding the right one.Does anyone happen to have the correct part number for this double pulley or know where he can order one (Paddocks ?)Hope my question makes a bit of senseEdwin. Quote Link to comment Share on other sites More sharing options...
Ben Reedy Posted August 17, 2005 Share Posted August 17, 2005 There must be a part number because some 2.5 turbos came with PAS, it would be the same. What I can tell you is that he will be amazed at how the heavier pulley acts as a damper on the engine and makes it much smoother. Quote Link to comment Share on other sites More sharing options...
exmodlad Posted August 17, 2005 Share Posted August 17, 2005 boy wouldn't you know it.......i have a couple of extra sets of these pulleys...brand new "Land Rover" parts too!!!!!.......i would sell them but i am in Canada so shipping might be an issue.......i will see if i can dig up the part numbers...... Gord 1986 exmod 110 2.8 Tgv Tdi "only the best will do" Langley BC Canada Quote Link to comment Share on other sites More sharing options...
western Posted August 17, 2005 Share Posted August 17, 2005 Pulley -- power steering & air condtioning ETC4105 or ERC6859 power steering only ERC6861 Quote Link to comment Share on other sites More sharing options...
exmodlad Posted August 17, 2005 Share Posted August 17, 2005 mine are the 2 peice assemblies as you will need the new crankshaft damper also as the original crank pulley for the 2.5 n/a deisel has no provision to bolt the new pulley on to it. damper .........# ERR 751 pas pulley .....# ERR 3093 gord Quote Link to comment Share on other sites More sharing options...
Smokydiesel Posted August 17, 2005 Author Share Posted August 17, 2005 Pulley --power steering & air condtioning ETC4105 or ERC6859 power steering only ERC6861 Thanks very much Guys ! Will pass the info on. Cheers Edwin. Quote Link to comment Share on other sites More sharing options...
western Posted August 17, 2005 Share Posted August 17, 2005 ERC6859 & ERC6861 are also used on the Defender type 200Tdi engines Quote Link to comment Share on other sites More sharing options...
darthdicky Posted August 18, 2005 Share Posted August 18, 2005 Ralph, any idea what the part number for the double pulley on a 2.5 petrol is? Would any other bits attached to that need changing too? Cheers, Richard Quote Link to comment Share on other sites More sharing options...
western Posted August 18, 2005 Share Posted August 18, 2005 Ralph, any idea what the part number for the double pulley on a 2.5 petrol is? Would any other bits attached to that need changing too?Cheers, Richard For 2.5 petrol fitted with-------------------- air cond & power steering use pulley------------------ ERC7089 power steering only use pulley---------------------------ERC5128 EPC shows no additional parts to fit. Quote Link to comment Share on other sites More sharing options...
