aerocorey Posted December 26, 2008 Share Posted December 26, 2008 There's a black wire with a female spade connector hanging down on the right side of the transfer case. I assume it's for the difflock indicator light since my difflock indicator light doesn't come on although my difflock works fine. Quote Link to comment Share on other sites More sharing options...
western Posted December 26, 2008 Share Posted December 26, 2008 if the attached end is under a bolt head on the difflock mechanism, yes the spade connector end should be connected to the difflock switch, very difficult to get at but not impossible, easier to remove the gearbox tunnel panel from inside the cab or to hard way from under the vehicle with a mirror to help locating the switch [looking from above the switch is on top face of front input housing to the rear inboard corner] hope that helps Quote Link to comment Share on other sites More sharing options...
aerocorey Posted December 27, 2008 Author Share Posted December 27, 2008 if the attached end is under a bolt head on the difflock mechanism, yes the spade connector end should be connected to the difflock switch, very difficult to get at but not impossible, easier to remove the gearbox tunnel panel from inside the cab or to hard way from under the vehicle with a mirror to help locating the switch [looking from above the switch is on top face of front input housing to the rear inboard corner] hope that helps That's exactly what I wanted to hear...been looking for an excuse to pull that access panel. Quote Link to comment Share on other sites More sharing options...
