lenny the lanny Posted December 29, 2008 Posted December 29, 2008 hi Ive just fitted s/hand heater and matrix but it still wont work no power at the dash controls there is power at both sides of the fuse box . it will work with directfeed please help Quote
western Posted December 29, 2008 Posted December 29, 2008 have you got the wires on the correct connections at the left fan switch slider ? or the slide switch might be dead. do a search for wiring diagrams too, I added some in the last few weeks for another thread. Quote
lenny the lanny Posted December 29, 2008 Author Posted December 29, 2008 have you got the wires on the correct connections at the left fan switch slider ? or the slide switch might be dead.do a search for wiring diagrams too, I added some in the last few weeks for another thread. the wires on the slider have no power black earth is ok as I testerd it with a bulb the two greens have no power to them tested the slider with multi meter and seem to be fine Is there a relay for the heater Quote
western Posted December 29, 2008 Posted December 29, 2008 did you test with ignition on, as these are ingition controlled circuits. there's no relay for the heater but in the heater box where the wires go in there is a resistor, but that sounds good as it runs with a feed applied. Quote
