Sebastian Posted December 30, 2008 Share Posted December 30, 2008 I am measuring the pressure of my 300TDi at turbo output, before intercooler. What should be the difference of pressure if I measure it at the inlet manifold? Quote Link to comment Share on other sites More sharing options...
rich90 Posted December 30, 2008 Share Posted December 30, 2008 Around 1-2 psi drop I would of thought. Quote Link to comment Share on other sites More sharing options...
white90 Posted December 30, 2008 Share Posted December 30, 2008 no drop on mine whatsoever otherwise I'd look for leaks Quote Link to comment Share on other sites More sharing options...
Sebastian Posted December 31, 2008 Author Share Posted December 31, 2008 Great thanks! I couldn't find the wastegate actuator, but since I am measuring 16 psi max, that should be ok. Also, I was wondering if it is ok for the turbo to start early giving 5-6 psi as soon as I hit the road. Quote Link to comment Share on other sites More sharing options...
patch1 Posted December 31, 2008 Share Posted December 31, 2008 Try driving it after the pipe has blown off the turbo and you will see why it starts so low. I find with mine that you have a about 10psi of boost even just crusing at 60. Quote Link to comment Share on other sites More sharing options...
