Posted
hi i have noticed that i have quite a bit of tyre wear on the inside edge of the driver side but the n/s is wearing even as normal ,have checked track rod ends and the drop link ? from steering box has a lot of wear,could this be the problem or something else ?? :(:(
all the best for 2009 joe.
Posted
Wear on the joints needs to be rectified but the most likely cause is that the tracking is way off - for some reason this sometimes affects only one tyre. Inside edge means too much toe-out which can also be a bent track rod as this has the same effect. Check the tracking before you invest in new tyres!
Posted
cheers will try it before shelling out :rolleyes:
